Question about RTO Oar Sockets
70 hp johnson outboard,was running fine,then started to blow black smoke from egsaust,lost of it ,then bogged way down
  • 4,340 Answers
Well, the black smoke is most likely from too much fuel, perhaps a stuck open float valve in a carb. Fix right away, or risk engine damage. Carb surgery is next on your list.
Posted on Apr 07, 2011
Testimonial: "Thanks! Cleaned um out and she fired right up-Great web site! Normal smoke now,appreciate it!!!"
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Why does my 1999 90 horsepower johnson idle but bogs down when accelerating
if this is a 2 stroke and went under water the problem may be damaged reed valves on the inlet side of the crankcase. Working all right when the air flow is low but do not seal of properly at rpms.. Suggest that you have an accredited outboard specialist look at it.
Dec 16, 2014 | Cars & Trucks
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
1992 60 hp motor bogs under full power????
try priming the fuel bulb when it boggs down and if it speeds up then replace fuel pump diaphrams etc and clean carbs and balance to start a fresh ! fuel tank clean ?
Jul 24, 2014 | Seloc Johnson Evinrude Outboards 65-300HP...
1985 johnson 85 hp outboard bogs under load
CHECK IGNITION COIL OUT PUT AFTER THEY HEAT UP. A WIRE CONNECTION (INTERNAL) COULD BE SEPERATING, NOT MAKING CONTACT AFTER HEAT EXPANSION
Jul 23, 2013 | Boating
1985 johnson 85 hp outboard troubleshooting
You can use auto scanner to check the engine system. Make sure i don't fault codes.
Jul 23, 2013 | Cars & Trucks
93" 115 H V4 Johnson outboard motor will start and idle fine
your carburetors might be dirty blocking flow to the high speed jets causing it to bog down
Jun 29, 2010 | RTO Outboard Motor Bass Fishing Boat Rod...
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
RTO Oar Sockets Logo
1,398 people viewed this question
Top RTO Boating Experts
ray gallant
Bill Boyd
Fabrice Wolters
Are you a RTO Boating Expert? Answer questions, earn points and help others
