Question about Toastmaster Kitchen Appliances - Others
My Toastmaster Waffle iron , Model W254 ,(1950) cord gets very hot when the iron is in use ,and particularly by the plug. It still makes great waffles but I'm concerned that something is failing. The cord is a woven black material with a silver/white thread running thru it. Thanks, Jim Snyder
  • jsnyder19 Apr 07, 2011
    Thank you for your help. I'll replace the cord as suggested. The one on E-bay,while showing the same part number , is round while mine is square . I guess that is feasible. Thanks again.
    I think it is the correct solution to my problem..
    President:
  • 2,080 Answers
You are correct in being concerned, especially if the cord is getting very hot in one specifc spot.
The cord may look unbroken on the outside but there may be hidden damage inside. If one of the copper conductor wires inside the insulation covering is cracked or broken, the current jumping across that fault area will generate a lot of heat. Enough current may still flow to your waffle iron to operate it for now, but very soon the unit will probably stop working alltogether or even start a fire first. I would recommend tou stop using it until you take care of the problem.
If you are handy with a screwdriver and a soldering iron you can probably disassemble the unit and replace the power cord right at the terminals inside the power connector. Or you can just ask an electrician to do it for you.
it's unlikely you will find an exact factory new replacent cord for that model, but that does no really matter electrically speaking. As long as you get a HEAVY DUTY replacement power cord and solder it right onto the terminals inside the waffle iron connector, it should work fine.
Another option is just to order a old used model off Ebay and just use the power cord that comes with that one, assuming of course that one is not a problem too! You can probably pick up the older models pretty cheap these days. Here's a link to a Toastmaster W252 model for $10 on EBay which probably uses the same cord and connector as yours:
http://cgi.ebay.com/Vintage-Toastmaster-W252-Teflon-Waffle-Maker-w-Box-/120706960381?pt=LH_DefaultDomain_0&hash=item1c1ab20bfd
Just search for TOAST MASTER WAFFLE on EBay and you will see a long list of others for sale too.
Please comment back here to this page if you have any questions, have difficulty accessing the link, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
Posted on Apr 07, 2011
What Is an Easy Way to Clean a Waffle Iron?
Here's a Toastmaster manual which explains proper cleaning.
Jul 31, 2015 | Toastmaster Kitchen Appliances - Others
How to use the waffler by toastmaster model# 2810R026
Directions
  1. Preheat waffle iron. Beat eggs in large bowl with hand beater until fluffy. Beat in flour, milk, vegetable oil, sugar, baking powder, salt and vanilla, just until smooth.
  2. Spray preheated waffle iron with non-stick cooking spray. Pour mix onto hot waffle iron. Waffle is usually done when it stops steaming. Cook until golden brown.
Apr 16, 2014 | Toastmaster Kitchen Appliances - Others
Toastmaster model 265 user manual
Indicator light shows the the heating element is on. Yes, it should be hot enough when the light goes off. The numbers at the following site may not match but you should be able to find the information that you need.
Feb 18, 2014 | Toastmaster Kitchen Appliances - Others
Need the manual and recipe
Here's a manual for my W252, which is similar to your model.
Feb 14, 2014 | Toastmaster 442A Vintage Waffle Iron
Need 2 prong cord for old waffle maker
The model # is stamped on the bottom side of the unit, or on bottom where the cord plugs into it. Once you have the model #, you can find a good used replacement cord on eBay.
Dec 07, 2012 | Toastmaster 200 Waffle Maker
Where do I find this perticular make and model? I need 2 or 3 of 'em
You are out of luck as this is an old problem the season is long past.
I am fairly shure that Toastmaster no longer makes this Pizzelle iron. A better solution is an American made Pizzelle Iron by C.Palmer
Built like a tank and will probably outlast you. I wouldn't buy a non stick appliance from anyone as the coating is easily damaged.
http://www.cpalmermfg.com/products/Pizzelle-Maker.html
Oct 31, 2011 | Toastmaster 208 Pizelle Maker Waffle Maker
283 S Waffle Iron.
You can try this site: http://kitchen.manualsonline.com/manuals/mfg/toastmaster/287.html
Its not the exact model but sometimes they are close. Hope this helps.
Aug 13, 2009 | Toastmaster 283S Waffle Maker
Repalcement plates for Model 270A Toastmaster Waffle Iron?
There is no way you can get replacement plates for you Toastmaster cheaper than you can buy a new one, the most expensive Toastmaster waffle maker I found was $30. the cheapest was $15 shipping will be at least half of that.
Feb 09, 2009 | Toastmaster 287 Waffle Maker
Kitchen Appliances - Others Logo
564 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
troup
Level 1 Expert
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
