Question about Konica Minolta Office Equipment & Supplies
C452 scanning error. Error details: login error, error code: 161 5/16 I set up a new folder for scanning and this is the errors I get when I try to scan to this folder. Its SMB
  • 2072 Answers
SOURCE: scan to smb
Setting up a scanning template using CentreWare Internet Services (CWIS) will fail if the user login name is a domain user, for example, ADSdomain\testadmin.
  1. Open an Internet web browser.
  2. Enter the IP Address of the machine in the Address field, and then press [Enter] on the keyboard. The CWIS home page will be displayed.
  3. Click on the [Services] tab.
  4. Click on the [Job Templates] link.
  5. Click on the [Display Job Templates Screen] button. The Device Template window will be displayed.
  6. Click on the [File Repository Setup] radio button. The File Repository Setup window will be displayed.
  7. Select the required File Repository from the File Repository Setup pull-down menu.
  8. Enter a username that only exists on the SMB server in the Login Name field.
  9. Click on the [Apply] button. A 'Settings have been updated' message will be displayed.
  10. Click on the [Back] button. The File Repository Setup window will be displayed.
  11. Click on the [Template] radio button. The Device Template window will be displayed.
  12. Click on the [Create New] button, and then setup the template again.
  13. Click on the [X] in the upper, right corner to close the Internet browser window and return to the desktop.
Posted on May 19, 2008
  • 2072 Answers
SOURCE: RE : Xerox WorkCentre M128 016-782
SOURCE: SMB Scanning
I had the same issue and fixed it by adding the group "Everyone" to the shared folder permissions (where I was sending my scans) and assigning the "Everyone" group rights to "change" and "read".
Posted on Jan 20, 2009
SOURCE: Scan job returns error job is done improperly. Check log 6385
I had this problem when sending to mail account.
This can also be changed for ftp/smb.
So maby this is the answer to you problem.
Solution: Extend the time-out from 90 to 300 seconds
Goto the setting of the machine (http://<ip>) and login with Administrator account.
On the page Network click on Email/SMTP.
Change the Time-Out setting to 300 seconds.
Good Luck!
Greets,
Ivan
Posted on Mar 18, 2009
SOURCE: KM 3060 Scan Error 2101
Hi Guys,
I was getting the 2101 error as well. I resolved this by placing the IP address of the computer into the "host name" field. Only thing to remember is that your IP address will change from time to time. You will need to assign a static IP to that particular machine or give it a reserved IP address through your switch. Good luck!
Posted on May 27, 2009
Toshiba copier E-Studio 2006 showing Error code C452 what could be a problem
Have you tried to check well your fuser unit because its fusing related problem where by those thermistor there not communicating well the temperature is either low
Nov 29, 2016 | Toshiba Office Equipment & Supplies
How to reset error code C452 in the Toshiba e studio 2006
1. Turn ON the power while [0] and [8] are pressed
simultaneously.
2. Key in "2002", then press [START].
3. Change the current status counter value "62" to "0", then
press [OK] (to cancel [C452]).
4. Turn the power OFF and then back ON. Make sure that the
equipment enters the normal ready state.
Jun 13, 2015 | Toshiba Office Equipment & Supplies
Konica minolta c 452 error code c 2161 & 2164
Hi
The descriptions for the two error codes you mention can be found at the two links below:
Error Codes Konica Minolta bizhub C452 Code C2164
Error Codes Konica Minolta bizhub C452 Code C2161
They would appear to be related to the same problem. For further information I think you would be best going to this page: Konica Minolta bizhub C452 Manual where there are many different manuals for this machine, which can be downloaded by clicking on the one you require and then following the instructions.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 20, 2014 | Konica Minolta Office Equipment & Supplies
Workcentre 5845 cannot scan to windows xp
My guess you have updated software that does not support xp.
Apr 03, 2017 | Office Equipment & Supplies
Am konica monlta c452
C-2553 is Magenta image unit so replace the unit, as for the 0214 0215 no such codes for that model of machine
Feb 18, 2014 | Konica Minolta Bizhub C452 Color Copier...
TROUBLE CODE C173
the error code given does not match any in the C452 diagnostics
if you meant CB173 then the error reports to the fax control pwb and page sizeing error. reseat the fax board/ reset the fax borad to factory and then reprogram to current location ( cleariing any possible programing mistakes previously) set the correct marketing area ( see service manual) it is very rare for a fax board to go down, the problem likely remains with its install/programming/firmware levels.
Jan 16, 2014 | Konica Minolta Bizhub C452 Color Copier...
Xerox WorkCentre M128 - 016 - 782
There is an error in the in the server password or a template setting.
Here is the documentation. Pretty straight forward
Login to the Server was not possible during Scan to Server file transfer.
arrwup.gifInitial Action Refer to BSD 16.1.
Power OFF/ON
arrwup.gif Procedure Set the login name and password in the destination server.
Set the attributes of the Job Template file correctly.
From a client PC, set the same account as the above as a resource using CW.
May 19, 2008 | Xerox WorkCentre M128 Copier
SMB Scanning
Mar 30, 2007 | Konica Minolta bizhub C250 All-In-One...
437 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
