Question about Getac M220, 14.1 XGA Display 1.6GHz, 2GB, 80GB, 802.11b/g, COMBO, Win XP - (M21C3B1B1A00) PC Notebook
Getac M220 Hard Drive caddy plugs into wierd socket. It is white, rectangular & "V" shaped. Its an IDE drive. _______________________________ ..................................................... \==========================/ 26 flat pins '\''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''/
4 Suggested Answers
  • 11 Answers
SOURCE: GETAC W130 Remove Hard drive
Hope I'm not too late.
You can access the hard drive by removing the bottom panel.
You need to first remove the battery cover, battery spacer, and then the two screws in the battery compartment.
Then remove all the large screws on the bottom plate.
Don't remove the little ones that hold the rubber port flaps, just open each flap so it won't get hung up on them.
Then take a flatblade like a mechanics size and insert it in the slot at the top edge just inside from the corners. They will be at the handle end of the laptop.
What you do is stand the laptop up on end.
Insert the blade at an angle while holding the handle in the other hand.
Lift the screwdriver handle upwards so that the blade grips downwards and lifts the bottom off the laptop. The slots I mentioned are not so obvious, but think of them as access holes and the bottom plate is wedged into the case like a can of sardines. If you stick your driver in there you can pry it up at the top and then it will open up and still be attached at the back until you open it up a full 90 degrees.
It will be a little tight at first but once it moves it come off freely with a couple wires attached.
I can send you a photo if you can't find the two openings.
You can access the hard drive in the middle left area without removing the entire cover.
You just need to open it wide enough to pry up the connector from the hard drive where it plugs into the board.
These are supposedly 1.8" drives so most likely you'll need to find an adapter to be able to recover your files. Usually a ZIF to IDE and then use a USB 2.5" enclosure or you might be able to order a ZIF to USB enclosure. I can help you figure that out once you pull it out. I swear I counted 46 pins on the mainboard side. I'm stumped until I see what you pull out of there.
I'm interested in photos and info on the drive and connector since mine is missing and I was to find something that might work instead of paying full cost from the manufacturer.
I also need an AC adapter for this damn thing, but it sure looks cool!
As far as laptops, it's way too heavy but the most Bad *** case on the planet.
Makes me think of the bad guy in those action movies...it's like some kind of super detonator tracking monitoring bleeping minefield activating superslick laptop the hero must disarm or destroy!
TELL ME THE DISARMING CODES NOW!!!!
Posted on Jan 03, 2009
  • 1542 Answers
SOURCE: Where could I find {preferably used} hard drive
Hi
i would have a look on ebay
www.ebay.com maybe type into search bar used hard drive caddy etc etc
Posted on Feb 22, 2011
oneStan
  • 430 Answers
SOURCE: I need a harddrive ribbon cable for Getac A770. I have caddy.
Try e Bay, I've found several unique computer cables I needed there, including SATA & PATA cables that were too expensive locally.
I also used that same resource to stock up on extra cables for PC expansions & repairs. They take a while, but they are priced low.
I've experienced very few issues with products purchased new from overseas.
Posted on Mar 22, 2012
Replace hard drive
Simple fix. Just remove the power cord, remove the battery, then remove the screws from the cover that houses the hard drive on the bottom of the laptop. Most times the cover will have the icon of 3 or 4 circular discs on it to represent the hard drive. Once you have the cover removed, there might be screws that hold the caddy inside the bay, if so remove them then you can lift the drive and caddy out of the bay. The drive might be inside of a caddy with screws holding it to the caddy. Remove the screws from the caddy and then you can remove the drive.
Notice what type of interface (IDE or SATA) your drive is and replace it with the same type of interface drive. IDE Drives have about 20 or so metal pins or prongs that stick out. SATA drives have two small plastic looking pieces that connect it to the interface inside the bay.
May 31, 2012 | HP Pavilion N5425 Notebook
How to remove hard drive
My hardrive is less than a year old and it will not power on. I tried a different cable and outlet. What is the problem and can i fix it?
It may not be the hard drive it self, it may be the caddy the drive is in. The best way to check if it is the hard drive is try the hard drive in another caddy, or plug it in to the computer without it being in the caddy itself using the PSU and SATA or IDE cables.
May 07, 2011 | Iomega (H0815VCA) 2 TB USB 2.0 Hard Drive
Where could I find {preferably used} hard drive caddy and power cors for the A770?
Hi
Feb 22, 2011 | Getac A770 Notebook
When I plug into the computer, computer does not recognize it MOST of the time. There are a FEW times it will finally recognize it, but doesn't keep it in the explorer. Help?
If the drive is used as an external drive ie. in a usb caddy, then check the caddy is fitted correctly and that the cable is not damaged. if the drive is internal, try using a different power connection and a different ide/sata socket on the motherboard also check if the drive is set to master, slave or csl (the jumper on the back of the drive next to the connection socket; there will be info on the drive (the white label on top) telling you where the jumper should go. If the drive is ide, and the drive is not the main drive but on the same cable as the main drive, the jumper should be set to "slave" or "sl" If the drive is sata, set the jumper to "master" or "ma". If all else fails, set the jumper to "cable select" or "csl"
hope this helps.
Jan 07, 2011 | Maxtor Hard Drive
When I open Dell 24000 I get an error sign primary drive 0 not found It tells me to hit f2-- but when I do I get no response. A colleague told me it was a loose cable so i have opened the tower but I do...
the hard drive IDE cables are flat, ribbon cables, usually grey and about 3 inches wide. do not confuse this with the floppy drive cable, which will look identical, except that it is 2 inches wide.
the cable could be loose on either the motherboard IDE controller end or the hard drive end, so wiggle it in tighter, or unplug and then re-plug it at both ends, and then try to boot. if that does not work, then replace the cable.
if a new cable does not fix it, then the hard drive itself may have failed. install the hard drive in a DIFFERENT working computer as a secondary (slave drive) by installing it to the middle connector of the IDE cable (IDE cables have a connector for the "master" or only drive at the end, and a plug for a "slave" drive in the middle of the cable), and see if you can access it. it will probably show up as the "E" drive under "computer" or "my computer". if it does not show up, check and see if it shows up under "administrative tools>computer management>disk management". if the drive is not showing up, then it is dead. if the drive works in the second computer, then the IDE CONTROLLER is the culprit.
if the motherboard's integrated IDE controller is dead, you may want to try the OTHER IDE controller socket. most computers from that era have 2 IDE controller sockets, and usually attach the hard drive(s) to one, and the cd/dvd rom(s) to the other. since the hard drive cables have plugs for 2 devices, you can attach both the hard drive and a single cd/dvd drive to the 2nd ide controller socket, in cases where the 1st ide controller soocet no longer works. attach the hard drive to the end of the IDE cable, and the cd/dvd drive to the middle of the IDE cable, as the "master" or boot device should always be attached to the end of the IDE cable.
you can also purchase an add-in, pci card ATA/IDE controller card, and use this instead of the motherboard's integrated IDE controller sockets.
Nov 06, 2010 | Computers & Internet
How do I size my hard drive mine is 4"wideX53/4 longX1" deep 40gb im looking for a caddy for it
This is almost definatly an E-IDE (PATA) desktop hard drive.
These drives are refered to as 3.5 inch drives, and laptop drives as 2.5 inch.
Just google ide caddy or enclosure
Sep 23, 2010 | Computers & Internet
Screen does not come on . cylinder shaped light (by the power light and on/off light) is not lighting up.
Sound like your Hard Disk drive is not starting up. They are normaly easy to replace, but i would try removing it & putting it into a hdd caddy, there is 2 types, 1 is the old IDe connection & the other is the Sata connection the bigger of the 2 is the IDE and has 2 lines of pins the Sata is normaly a female connector on the drive.
If you can get hold of a caddy insert it & connect it to a freiends pc or laptop to see if it works, it saves buying a new hdd if its not faulty.
Nov 08, 2009 | ASUS Eee 4G Notebook
Computers & Internet Logo
164 people viewed this question
Top Getac Computers & Internet Experts
David Payne
David Payne
Are you a Getac Computer and Internet Expert? Answer questions, earn points and help others
