Question about Sony KDS-R60XBR1 60" Projection HDTV
My Sony kds-r60xbr1 keep turning off right after the picture pop up and the green power light keep blinking. What's the problem that need to fix?
  • 1,476 Answers
Llew_mao,
See my tip at http://www.fixya.com/support/r7851924-sony_projector_yellow_or_blue_dots I believe you have the same problem.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Apr 07, 2011
Sony KDS-R60XBR1 No picture
Sounds like your light engine might have broken. Its around a $400 fix and I noticed Tri-State is having a sell on there about 341 its easy to replace it here is the link
http://www.tristatemodule.com/casearch.aspx?SearchTerm=kds-r60xbr1&asug=&view=grid&lang=en
May 14, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Blink on standby green after awhile then blink red
The blinking green light signals that the inverter board is charging the bulb. If the blinking goes to red it means that this process has failed because either the inverter board is not full operational or the bulb itself has failed.
Most likely you will have to replace the bulb - here it is
http://www.partstore.com/Part/Sony/Sony/KDSR60XBR1/Royal+Philips+Electronics/Philips+Lighting/F93087600RL/New.aspx
If this doesn't fix it then you will have to check the inverter and power boards and replace the failing one.
Here is the ballast/inverter
http://www.partstore.com/Part/Sony/Sony/KDSR60XBR1/Sony/Sony/146893613/New.aspx
Here is the power board
http://cgi.ebay.com/SONY-KDS-R60XBR1-G-POWER-SUPPLY-1-867-733-11-Free-S-H-/120703310513
Mar 27, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R60 XBR1
I've heard thiis is a fan issue that you need to replace an exhaust fan which is pretty cheap
Sep 14, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
KDS-R60XBR1 60" SXRD HDTV
I had the same problem if it is blinking 4 times like I think it is... it is a problem with one of the fans (there are 4) in your TV.. It is a simple fix... try using an air canister to clean them. It will require some disassembly though.
Sep 12, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R60XBR1 60" Projection HDTV Logo
150 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
