Question about Nintendo Wii Console
Wii will not conect to the internet today, we have not had a problem before today. When I test it it shows an error code of 52030.
  • Nintendo Master
  • 441 Answers
The following information was taken directly from Nintendo's website about error code 52030. I have included a link at the bottom directly to the page from which I got this information. If you click the link, there will be a step by step guide on fixing the error:
Error 52030
Unable to connect to your wireless network
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow, or your router is not able to assign the Wii an IP address.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings; manually assign an IP address to the Wii.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=en_US&action2.x=29&action2.y=19
Posted on Apr 07, 2011
Can not connect to internet on my wii error code 52030
It's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console
Jun 04, 2012 | Nintendo Wii Console
Tip
Nintendo Wii Error Code 52030 The most likely cause of error 52030 is that the...
Nintendo Wii Error Code 52030<br /><br />The most likely cause of error <b>52030</b> is that the router securityinformation was entered incorrectly on your Wii or that your router is unableto assign an IP address to the Wii.<br /><br />If this problem <b>just started</b>, and your Wii was working before, then tryto <b>power cycle</b> your equipment. Turn off the modem, router and Wii. After10 seconds turn on the Modem, after 30 seconds turn on your router, and after30 seconds turn on the Wii.<br /><br />If this does not work then continue below,<br /><br /><b>Make sure</b> your wireless <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>network<span>security</span></span></span></a> password and security typeis entered into your Nintendo Wii correctly. You can go into your routersconfiguration page to view the security key and view security type. If needed,you can change these. On most routers, you can access the configuration page byopening your Internet Browser and going to the router ip address(gatewayaddress) 192.168.1.1 This address may vary from router to router. Once you goto this address you should get a login page. Login and then go to your Wirelesssettings page to view the settings you need for your Wii. Once you verify thesecurity key and type, input these settings into your Wii and test theconnection. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> for my <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>tech</span></span></a> article on how to configureinternet settings on the Nintendo Wii.<br /><br />Tip - To view your gateway address in Windows do the following,<br />Go to Start &gt; Run and in the run box type "command" or"cmd". A black DOS window should open. In this window type"ipconfig /all" you should <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>now</span></span></a> see a gateway address.<br /><br />-<b>Most home networks </b>will use DCHP. What is DCHP? This is Dynamic HostConfiguration Protocol. In short, it means your router or <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>server</span></span></a> will assign IP and DNSaddresses out automatically, with no intervention needed from you. If you aremanually using settings(not using DCHP) you will need to assign an IP/DNSaddress to your Wii.<br /><br /><b>To get </b>to the Wii settings to input an IP address and DNS address, dothe following,<br /><br />Access the Wii System settings and select "Internet" from Page 2.<br />Select "Connection Settings" and choose the connection file youcurrently use (will have a red border around it).<br />Select "Change Settings," and click the right blue arrow twice toreach "Auto-Obtain IP Address."<br />Click on "No" and select "Advanced Settings."<br /><br />Enter in your IP address, DNS address and subnet mask information.<br /><br />A Wii connection test should confirm the internet is now working. Again, mosthome networks use DCHP so you may not need to set an IP address.<br /><br />-<b>Interference</b> can also cause this issue. Try and make sure there are nowireless devices around the Wii and router and the Wii is in an open areawithout devices blocking it.<br />-<b>Change your router's channel</b> setting to 1 or 11. By default, mostrouters broadcast on channel 6, which overlaps with other channels and may beweaker.<br /><br />If you are still having trouble, you may want to reach out to NintendoTechnical Support at 1-800-255-3700<br /><br />-G33k<br /><br />Check out some of my other tech articles!<br /><a href="/../support/r9300521-nintendo_wii_error_code_51031">Nintendo Wii Error Code 51031</a><br /><a href="/../support/r9300387-tuneup_utilities_prefetch_data_deleted">Tuneup utilities prefetch data deleted</a><br /><a href="/../support/r9275311-computer_freezes_computer_stuck">Computer freezes, computer stuck</a><br /><a href="/../support/r9256225-disable_enable_microsoft_windows_startup">How to disable/enable Microsoft Windows startup programs</a><br /><a href="/../support/r9223119-garmin_gps_stuck_not_updating_no">Garmin GPS - stuck , not updating, no signal problems</a><br /><br />Keywords<br /><b>Nintendo Wii Error Code 52030, Wii error code 52030, Wii 52030, Nintendo Wiiinternet issues, Wii internet, Nintendo Wii internet</b>
on Jun 02, 2011 | Nintendo Wii Console
Lost internet connection reading code 52030
Error Code: 52030
Jul 20, 2011 | Nintendo Wii Console
When I try to connect to the Internet it keeps giving me a error code 52030
Error 52030 is a security settings error built into the Wii. This means the Wii is either incompatible with your router's security settings or your router isn't able to assign the Wii an IP address (which means it can't register it onto your network).
Nintendo has provided official information for solving this problem here: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=lang
Mar 12, 2011 | Nintendo Wii Console
I have a wii connected to my internet but I can1t get into my netflix, error code 52030 shows
When I had Netflix they had a very good support group who could, if necessary, remote access your computer and correct the problem. You should be able to view using your pc or wii. I'd try letting them have a crack at it. Of course contact them on the internet. Hope this helps.
Dave
Mar 12, 2011 | Computers & Internet
My wii will not connect to wireless internet error code 52030
If you get an error code of 52030 on you Wii console, this indicates a problem with your Wii communicating with your wireless router. There are a couple things you can try/check to help fix this problem.
1 - Try using a different channel on your router and update your Wii to take to the router on that channel.
2 - If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
Feb 28, 2011 | Nintendo Wii Console
I'm trying to connect my wii to the internet but every time i test the connection it says error code 52030 what does it mean
dont worry it seems to be a small problem.................
and u can easily resolve your problem
Click Here to download the repair guide
Dec 13, 2010 | Nintendo Wii Console
I have an Error Code 52030 on my WII. What does
it means that u are trying to connect to wifi but there is no wifi around so go 2 tech support for wii and enter the error code.:)
Jan 30, 2010 | Nintendo Wii Console
Error 52030 in internet connections
one option is try choosing a different type for your password...i've had the same error before and what i did was to change the password type e.g. from wpa aes-tkip to wpa-aes passphrase (this option will appear during your wii internet connection set-up as you would probably know by now) and everything right afer started to fall in place perfectly...my wii started connecting to my router and never had the same error code ever since.
Nov 23, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
221 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
