Question about Garden
Soldron soldering iron 25w 230v is not heating.
2 Suggested Answers
jdvillanueva
  • 2098 Answers
SOURCE: Weller 25w Sp32L Soldering Iron
replaced the heating element....
Posted on Dec 26, 2010
Pro video camera repair
hey snight
you can just use a small pick or tweezer to take of the broken connector. it wont do much now because its broken.
what you can do is that you can bring that camera to a place where they sell camera accesories and tell them that your looking fore an exact replacement for your jvc.
Apr 09, 2008 | JVC Everio GZ-MG21 Camcorder
Hi i have an old weller soldering iron and it wont light up, do i have to have the 2 slide controls in a certain position
A soldering iron is composed of a heated metal tip and an insulated handle. Heating is often achieved electrically, by passing an electric current (supplied through an electrical cord or battery cables) through the resistive material of a heating element. Another heating method includes combustion of a suitable gas, which can either be delivered through a tank mounted on the iron (flameless), or through an external flame.
Mar 24, 2011 | Milwaukee Tool Weller Pyropen Jr Cordless...
Weller 25w Sp32L Soldering Iron Failing to heat up
Dec 26, 2010 | Garden
I just bought the soldering gun but the instructions on the package aren't very useful how do i use the gun?
A soldering gun is used much the same as a soldering iron for melting solder mainly to connect electronic components to circuit boards. To use it you plug it into the electricity mains and press the trigger. This causes the metal tip to heat up. Allow a minute or so for it to reach full heat and press it to the components you want to solder together. When they heat up press the solder against them. The solder melts and runs on and between them forming a bond. Remove the soldering iron and release the trigger. Once the trigger is released the gun starts to cool down again.
If you've used a soldering iron before you'll probably find the gun more awkward as it cools down every time you release the trigger. It's really only useful for quick jobs where you're not going to need it every few minutes. For other jobs where a lot of soldering is involved a soldering iron is better. The advantage the soldering gun has over the soldering iron is that it heats much faster for quick jobs.
Dec 04, 2010 | Cooper Industries Weller 7200PK 75 Watt...
Soldering iron doesn't heat up.
The problem is very likely to be a burn-out heating element in your soldering iron: it will now be open-circuit and you can verify this by using a multimeter on the resistance measuring range.
Hope it helps.
Jul 26, 2010 | Weller Marksman Iron 40 Watt SP40L
Iron is not heating up hot enough stained glass soldering iron:
hi friend,
check this out
Consider the wattage of the soldering iron. A good soldering iron will have wattage of 80 to 150. A wattage of lower than 80 is not ideal for stained glass. You need a soldering iron that will melt the solder fast enough for your project. Consider the type of temperature control you want. Some irons will have a temperature control built in the tip. When the temperature drops, it will turn on and when the temperature is reached, it will turn off. Other soldering irons have a built-in rheostat. You control the temperature by turning the dial up or down. A separate rheostat can be purchased to plug your soldiering iron into. Rheostats are highly recommended. This lets you match your temperature to your soldering style and allow you to do decorative effects.
  • Step 2 Consider the heating element. There are two types of elements, ceramic or wire-wrapped. Ceramic core irons maintain heat more efficiently than wound wire heaters. In a ceramic core, the heater core extends into the tip for faster heat transfer. This will keep the tip hot for a longer period so you can work quickly and faster. Ceramic irons maintain their temperature longer and heat up within 30 to 60 seconds.
  • Step 3 Consider the weight of the soldering iron. You want a soldering iron that is lightweight and balanced. You will have less fatigue when using a lightweight soldering iron at long stretches of time. Check to see if it fits your hand comfortably. Check to see if it has a good rubber cushion for your hand.
  • Step 4 Check for the ease of changing tips on your soldering iron. When soldering stained glass, you want to match your tip to the technique you want to use. There are a variety of tips on the market for soldering irons, and you want to be able to change them easily.
  • Step 5 Check the soldering iron to see if it has a heavy-duty cord and a three-prong plug. You want a grounded three-prong plug to prevent the possibility of shock.
  • hope this helps u
    please rate me......................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Weller Welding Tools
    The pin of my headset bend and now it works only half the time, any hints on how to fix it?
    This is not easy to fix as the connector is usually molded plastic. If you have access to a soldering iron of low wattage (25W) and a small tip you might be able to replace the complete cord all the way to the headphones. This type of job is not quick and wires have to be disconnected at the earpiece. Sorry.
    Jul 11, 2009 | Creative Labs Audio Players & Recorders
    Need info wont turn on
    the set will not operate with out proper vertical signal/deflection. you may have bridged pins together when resoldering. use a 25w or 35w soldering iron so as not to lift copper traces from pc board. always use solder wick to remove old solder and DO NOT keep on pad to long. mch
    Feb 20, 2009 | Hitachi 36UX01S 36" TV
    Garden Logo
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
