Question about Electrolux Vacuums
I have an electrolux discovery II vacuum cleaner and the floor function works, but when I try to switch over to carpet mode, it doesn't seem to engage.
There is a red reset button on the back of the machine. When it trips, the brush won't engage. Press the reset button and then try your machine again.
Posted on Aug 11, 2012
  • 30 Answers
SOURCE: fixing my vacuum cleaner
Check to make sure that your agitator still spins. (Agitator = brush). If your agitator still spins, it eliminates your belt and agitator as likely culprits. The last possible solution would be that your vacuum is clogged. The grinding sound might be a motor-related issue or could possibly mean your bearings are going out. Check the bearings of the agitator and the motor of the vacuum.
Accessing to the agitator and belt can be done by removing the bottom cover of your vacuum. There are 2 scews that are holding the bottom cover to the head of the unit. Remove these 2 scews and the bottom cover should snap off.
Posted on Mar 07, 2008
  • 70 Answers
SOURCE: Electrolux 1572E (Discovery II) How to remove
Remove the handle assembly by taking the big screw out and pull up on the handle. Remove the four screws where the top half connects to the bottom half. Two on the outside back and two on the inside front where the bag goes. You'll need a long phillips #2 screwdriver. Always have the power disconected. Pull up on the bag housing while twisting it side to side.
Good luck after you get in.
Posted on Aug 10, 2009
reddevil6
  • 1673 Answers
SOURCE: Electrolux diagrams and schematics
Sorry, I don't, but you cn look on line or phone book for Aerus Electrolux. But if they will ive you any info, I don't know. Sorry I couldn't help you out.
Posted on Jun 17, 2008
  • 1214 Answers
SOURCE: Kenmore Vacuum 116.36623501 does not stay on bare floor setting
It sounds like there is something wrong with the latching assembly. GO to the Sears Parts website and enter your Model number. Look at the parts assembly for the Nozzle, and the problem will be in one of items 12 through 17.
Posted on Jan 15, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
Brush roller works on carpet setting but not on floor setting. have already cleaned roller. suction is great. just won't do anything on floor setting (all 3 settings)
Check the arms that make the roller go up and down to achieve the settings. There may be something clogged in there.GOOD LUCK FRIEND
Sep 14, 2014 | Electrolux EL8807A Precision BrushRoll...
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
Precision model blockage
No solution but we seem to have the same problem it is as if the valve isn't working. Please don't tell me to check for blockages.
Feb 24, 2014 | Electrolux EL8807A Precision BrushRoll...
Electrolux VACUMM CLEANER LITE II
get new bag filter , empty dirt out to garbage bag , clean hose .
Dec 26, 2013 | Vacuums
My DC24 will not switch from floor to carpet mode? Roller is not stuck or full of lint. Bagless is clean.
I'm sorry to hear you're having difficulties with your DC24. If the brushbar will not rotate when the brushbar switch is pressed, you may need to reset the machine.
With the cleaner facing you, you'll find a button in the red recess on the left-hand side of the cleaner head. Press this in until you hear an audible 'click' - it may help to use something like the eraser-end of a pencil to do this.
The brushbar will never rotate when you have the machine standing in the upright position, so please make sure you have it reclined into the vacuuming position before testing it after pressing the reset button.
This should resolve the issue - however, if you do need any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can help.
Best wishes,
Jack
Dyson Online Customer Support
Jan 26, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Does not seem to adjust to different carpet sizes
Hi Denise,
DC14 is engineered to adjust automatically to suit the type of flooring you're using it on. You can also use the brush control on the cleaner head to turn the brushbar on for vacuuming carpets, and off for vacuuming hard floors.
However, if you're concerned the cleaner doesn't seem to be working correctly, please follow the steps shown in our online support guide to identify and resolve any issues:
http://www.dyson.com/support/help.asp?article=626&product=DC14-ANIMAL_US
If you've tried this and still feel the cleaner isn't picking up as well as usual, please get in touch with us directly so we can help - you can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Oct 28, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Just got my dc33... one issue... the dial switch to control btn bare floor / carpet mode doesn't seem holding in it's position when I set to the bare floor mode... it keeps coming back to carpet...
I'm sorry to hear you're having difficulties with your DC33. If you're concerned that the brush control doesn't seem to be staying in position, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to check everything is correct with your machine, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Aug 24, 2011 | Dyson DC33 Bagged Upright Vacuum
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
We have two of these vacuums and both of them have experienced the same problems. First the floor heighth adjustment doesn't work and now neither one will pick up on either carpet or floor when in the...
Did you check the powerhead for obstructions? With a bend in the tube just below where the hose connects, this is a common spot for clogs. To check, detach hose and drop a coin in the hole. If it doesn't drop through, a blockage is present. Use the handle of a wooden spoon to push clog back through to brush. It can be removed with long-nose pliers from there.
For height adjustment, check for debris that may be preventing the nozzle from raising and lowering. There may be something inside the powerhead preventing it as well.
The manual can be found at the following site. On the left side of the page, under the image, click on the Use and Care Manual button.
http://www.abt.com/product/20743/Electrolux-EL5035A.html
Jan 21, 2011 | Electrolux Oxygen 3 Upright Vacuum Cleaner...
I have an Electrolux Oxygen 3 Ultra Canister Model No Rel7020. I am having problems with the On/Off Button and the Bare floor/Carpet Brushroll On/off button. The Carpet On/Off will not work at all. In...
You have a problem with the electrical switches. If you are comfortable with this, take apart and double check internal wiring to make sure nothing was frayed, or disconnected. Make sure it is unplugged. If you know how to operate a multimeter, you can use it to check continuity in each switch.
Jan 27, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
413 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
