Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I need a copy of the manual. My washer wil not start. It fill with water but did not start
    Brigadier General:
  • 6,277 Answers
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Good luck,
John C.
Posted on Apr 07, 2011
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Jul 28, 2013 | Haier HLP23E Top Load Washer
I have a series 80 washer. it will fill with water but wil not start washing.
check your timer motor. if the front indicator knob isn't rotating or you don't hear a motor noise it will more than likely be the problem.
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
Hot water entering machine is only a trickle. It
Check the filter trap on the back of the washer where the hot water fill hose connects to the inlet valve, you wil have to shut the hot water valve off first, then remove the hose at the washer and inspect the little filter screen thats in the valve where the hose screws onto the washer, it probably has trapped enough sediment to restrict the flow of hot water into the washer.
Good Luck !
Mar 14, 2010 | Washing Machines
Wil not start
you may have to center the tub and reset the off balance switch by opening the lid all the way and centering the tub
Feb 26, 2010 | Speed Queen AWS45NW Top Load Washer
LST8244BQ0 Should I just get a new washer? Overflows with water, keeps on filling. Stops filling when you switch to rinse cycle from wash cycle though. Drains well. I may have overloaded when I was washing...
Simple fix. But you might need a tech. Sounds like your water level switch needs fixed or replaced. Most work on air pressure. (Huh? your saying? :) A tube (you can't see) runs down the verticle length of the tub. As the tub fills with water the air in the tube increases the air pressure within it. There is an air pressure switch on top of the tube and the "Washer Load Size" switch adjusts so that when the air pressure is correct (water level in the tub) meets the requirements of what you set it to, then it turns off the water inlet valve and starts the washing cycle.
If this "water level tube" gets disconected, it will not work. Also if it gets cracked (it is plastic) or gets plugged somehow, or if the switch fails, you wil have water, water everywhere.
Here is the manual online -
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=LST8244BQ0&siteCd=WHRCOM
Whirlpool's Toll Free number is number is: 866-698-2538
and thier customer service Web site is: http://www.whirlpool.com/custserv/index.jsp
Hope this helps - If so - Check "Fixya" below!
Len
Jul 26, 2009 | Whirlpool Washing Machines
Tub will not start the wash cycle when filling, and will not stop filling
Hi, sounds like you wil need to change the inlet mixer valve. Did it continue to fill with the washer turned off? Let me know so I can assist you further.
Thanks
Vic
May 16, 2009 | Washing Machines
Maytag neptune starts to fill with water then stops
Water inlet valve sounds faulty.
Fill s to slow so it automatically shuts off.
Not a do it your self problem.
Apr 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Indesit wil 113
this is a cold fill only machine as nearly all machines today are designed that way to save energy , as you only heat the water that you need
Mar 28, 2008 | Indesit W 123 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal De
