Question about HP Photosmart C6180 All-In-One InkJet Printer
HP ERREUR 0xc18a0206 sur C6180 - HP Photosmart C6180 All-In-One InkJet Printer
I have an HP Photosmart C6180 i get error 0xc18a0206
Welcome to Fixya.
Here's how to resolve this issue :
HP Photosmart Reset
Basically, this error denotes "Ink System failure" and can be resolved by Printer reset. Follow the easy steps and you should be good to go.
Thanks for using Fixya.
Aug 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
Error 0xc18a0206 for HP Photosmart 3310 All-in-One
Hello and Welcome!
The error
0xc18a0206 is mostly occurred in HP printers
To solve the error code
0xc18a0206, Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
But if u face still this error then printer service required.
In that condition best option is to Contact HP Service Provider
I hope this solution helps you
Thank you for using FixYa
Apr 19, 2011 | HP Photosmart C6180 All-In-One InkJet...
J'ai desinstallé par erreur le
Salut ,
Sauf erreur , c' est du HP ça . Des pilotes sont disponibles ici :
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=ob-40706-1
J' espère t' avoir été utile .
Cordialement ,
Dec 19, 2010 | Computers & Internet
Bonsoir, Description du pb : "Echec système
En anglais - c'est trop longtemps que je parle francais...
The code you mentioned sounds like an Ink System Failure code. My C6180 had the 0xc19a0035 Ink System Failure code, eventually the printer would power on and off every 15-20 seconds - continuously. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other HP printers. acca299.jpg
Dec 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
Erreur 105 serveur introuvable
Cette erreur est généralement provoquée par le programme de sécurité.
Norton est connu de bug chrome. Essayez de:
1.Ouvrez Norton Internet Security
2. Cliquez sur Firewall personnel et cliquez sur Configurer
3. Cliquez sur l'onglet Programmes et défiler jusqu'à Chrome.exe
4. Changez-à-dire "Autoriser tous"
5. Open Chrome
J'espère que cette aide, wbwTeam
Mar 25, 2010 | Google Chrome
HP Photosmart C6180 All-In-One InkJet Printer Logo
239 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
