Question about GE Wireless Optical Mouse
Mouse 98812 does not work. when I plug receiver into my computer it makes a sound as if the computer recognises it but the mouse woun't move the pointer. Thanks cloader66@aol.com
    Guru:
  • 811 Answers
Make sure that the batteries are changed out then try it again if that is not the case and the batteries are all good then make sure that the distance is within range or nothing is in front of the receiver like a cell phone or a phone or anything like a lap top have nothing in the path that is electronic I do hope that this assisted you if so please post a good vote for me thanks for using FixYa! John
Posted on Apr 07, 2011
How to install 2.4Ghz wireless mouse with USB receiver?
Insert the batteries into the mouse. Turn the mouse over, find the battery cover, and slide it off. Insert the appropriate batteries-usually two AAs.
  • The wireless receiver that plugs into the computer uses USB power, so it needs no batteries.
Connect the receiver to the computer. If your computer has a USB port (as most do), plug your receiver into an available port. There will also be a green adapter supplied, in the event that your system requires the use of the mouse port. Caution-don't try and force the mouse adapter into the keyboard port!
  • The mouse receiver has a USB plug (left), but can also plug into the mouse plug through the adapter it came with (right). If your receiver plugs into the USB port it should look like the left. If it plugs into the mouse plug it should look like the one on the right, only connected to the receiver.
Connect the mouse to the receiver. Place the mouse in close proximity to the receiver, and note the following:
  • The receiver should have a visible button that is easily pushable by the average human finger.
  • The mouse will usually have a very small reset button in a hole on the bottom that can be pushed by something like a pencil or paper clip.
  • Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
Find a permanent position the receiver. Place the receiver where it won't be far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk.
  • The furthest a wireless mouse can get away from the receiver and still function is about 9 feet (2.7 meters), so keep that in mind.
Test your new mouse.
  • If you plugged into the mouse port, restart your computer.
  • If you plugged it into the USB port you should be able to use it immediately.
  • When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Adjust your mouse settings. Use the control panel that came with your wireless mouse, or download the necessary software from the manufacturer's website. Adjust the settings so that the mouse performs as you require.
Oct 18, 2014 | Computers & Internet
Purchased new laptop and wireless mouse, first day worked great, after a week tried to use mouse again.....just not working have replaced battery no luck
I would try unplugging the usb receiver and restarting the computer.
Then plug it back in.
Sadly, with these, along with replacing the battery, that's the only option.
Mar 12, 2011 | HP Wireless Optical Mouse
My 98812 mini mouse does not Put new batteries
Try plugging and unplugging the usb adapter a few times first. You might also try it in another usb port, sometimes that will, miraculously, fix it. Then, maybe reload the software. Good luck!
Mar 19, 2010 | GE Wireless Optical Mouse
My 98812 mini mouse lights up but will not move the pointer i have vista
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | GE Wireless Optical Mouse
I have an hp wireless mouse, and it doesn´t work!! Tried everything...
Wireless device like the mouse needs a wireless connectivity to a computer like a bluetooth or a wireless receiver. Make sure that your mouse batteries are all working and the wireless receiver is properly plug into the USB(Universal Serial Bus) port of the computer. The wireless receiver don't need battery so you don't have to worry about it. The two both have a push button, press both buttons to activate the connection. Wireless connections has limit in distance so make sure that you are not too far away from the receiver while using the mouse and that is 9 feet or 2.7 meters so keep that in mind. When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Hope this could help you a lot..:-) Thanks..
Dec 27, 2009 | HP Wireless Optical Mouse
Mouse will not move the curser.
Are your other mouses USB? What version of windows are you running? Have you shut down your computer and unplugged the old one... Then plug the new one in and start it up..
Sep 29, 2009 | Ultra Max Gigaware Wireless Laser Mouse
ADE-EMB1 mouse wont work
Mouse might be broke. If you have another computer to check with make sure it does the same things. If if works with other comptuer then there could be software driver problem in the computer.
Sep 16, 2009 | Computers & Internet
It will not connect and I can not find the product number anywhere it is a 98812 ge mouse
if you press connect on the bottom of the mouse and then press connect on the USB thats plugged into the computer it should work.
Aug 16, 2009 | GE Wireless Optical Mouse
Technika optical wireless mouse not working
Make sure the mouse is linking to the wireless receiver on you have plugged into the computer (there should be a reset button on the mouse to establish a new link).
May 13, 2009 | Casio Parts Cash Register PC Desktop
Targus amw20euk has installed on my vista computer but the cursor wont move when i move the mouse
Make sure that you SYNCHRONIZE the remote mouse with the receiver (plugged into computer)
*make sure your batteries in the mouse are good*
1) Turn mouse on
2) Press "CONNECT" button on bottom of mouse
3) Press "CONNECT" button on receiver
Check mouse functions-it should now work.
REPLY if problem still persists, I will try and help you further.
Hope this helps.
Dec 20, 2008 | Computers & Internet
GE Wireless Optical Mouse Logo
79 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
brian soufane
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
