Question about E-Machines (308714) Motherboard
Have emachines t6520 need to know power switch connectors and led etc. go on motherboard
  • 73 Answers
There should be white text next to the front panel connector on the motherboard labeling which connector goes where. this may also help:have emachines t6520 need to know power switch - garthok.gif
Posted on Apr 07, 2011
I need the wiring diagram that shows where on the motherboard to plug the power switch ,power LED, and HDD Led on a T6520 emachine desktop
Most Motherboards are made to only accept certain plugs in that specific spot! If you are trying to add something new like a new Fan or LED, or HHD and you need power you would have to use a 4 prong plug off the power supply, If your power supply does not have any more available plugs, Amazon.com or Newegg.com sells splitters!
Good Luck and Best Wishes!
May 03, 2011 | Computers & Internet
I need the diagram for the motherboard that is installed on my emachines model t6520. Do you know where I will be able to find one?
I Goggled your model and came up with this website: http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T6520
Jan 04, 2011 | E-Machines eMachines Desktop PC
I am trying to find the power switch diagram for an emachine t6520 thanks
On a Asus motherboard its not designed for eMachines systems because they come with a proprietary setting on the case. So what you need to is take the emachines motherboard that you took out and take the new motherboard that you bought and match the two. If there is a difference then you need to return it or buy a new case and you shift all the hardware from the emachines to the new case. If not buy a similar replacement board from emachines or ebay and you can find one and buy it. The Power setting is on all motherboards but some are different then others.
Dec 04, 2010 | E-Machines T6520 PC Desktop
I NEED TO KNOW HOW TO CONNECT THE POWER SUPPLY FOR AN EMACHINES T1120 COMPUTER. CANNOT FIND A SCHEMATICS DIAGRAM ANYWHERE.
After reading an article about Emachines awhile back, I found out the reason you can't find the schematic- it isn't available, as some motherboards are made specifically for Emachines and therefore not distributed, as they might normally be, but again, others are, but you have to identify them and go through another source to get them- Emachines, appartantly, will not supply them. All is not lost, however...all motherboards have, basically, the same hookups and connectors for the power supplies, hard drives, etc.- they are standard. I found a web blog that explains the power switch, reset, and power led, which will help. Here it is: http://www.computing.net/answers/hardware/emachine-power-sitch-wiring/56545.html
This site will explain about the 24 pin connector from the power supply
http://www.tomshardware.com/forum/53750-7-installation-manual-rs480m-w3400-emachine-motherboard
If you google "motherboard wiring" you will find sites that have illustrations of the motherboard, and explain which connectors go to which sockets, and how to identify them.
With a little patience and determination, you should be able to hook everything up from the various blogs on the net. Hope this helps.
Apr 17, 2010 | E-Machines eMachines Desktop PC
Need to re-attach power button cable, hard drive
The manual for your computer is available from emachines, p.168 shows the info you need (replacing the front I/O panel)
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The good news is that you can't harm the computer by connecting the wires wrong and the bad news is they just won't work the way they are supposed too if not connected properly. The LED's must have the correct polarity to work.
In general, if you look real close (as in magnifying glass and flash light) you will see the ID for each set of pins is printed on the motherboard (pwr,rst,HDD,pwr sw,speaker) Just match what it says on the motherboard to what it says on the wires. Don't worry if you get the polarity wrong. If a light doesn't work just swap the two wires. The colored wires should be positve (+), though. The reset (rst) and power switch (pwr sw) wires don't require polarity.
These instructions are for most computers in general, YMMV.
Nov 30, 2009 | E-Machines eMachines Desktop PC
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Emachines t3830 I need the schematic for MB I umployed the wire for the push bottom without looking at the way they were plug. Now I do not know the correct aligning of the push bottom wires.
If you look at the motherboard there is usually a diagram labeled "FRONT PANEL HDR" that will tell you which pins are for: HDD LED, PWR LED, RESET, PWR ON. etc.
The chart / diagram may be a few inches away from front panel header.
the following example is from my emachine T2893 that I had opened because it won't power up.
the motherboard at the header connector labels pin #2 and with that you can figure out the other
pin numbers
example of diagram on motherboard (Confirm the pin numbers on your motherboard)
J9G1 PINS
| HD LED | 1 - 3 |
| PWR LED | 2 - 4 |
| RESET | 5 - 7 |
| PWR ON | 6 - 8 |
Hope this helps you figure which pins to hook you switch up to.
Jan 18, 2009 | E-Machines eMachines T3830 PC Desktop
Wires unpluged
these normally go at the front of the motherboard if you are looking at it where the power supply box cables are at the back. There are litlte pins that these fit onto that will say on the motherboard Hdd led etc... in small writing.
hope this helps
Oct 31, 2008 | E-Machines eMachines Desktop PC
I have an emachines t6520 and the power sw wire, HDD led wire, and the power led wire hve been disconected
On the system board, on the left edge next to the primary IDE connector, there is a 9 pin header.
I usually get a magnify glass and look down on the header . From right to left,you will see PWR led pins closer to the edge of the motherboard.and the Power BTN next to it.(the side of the pins that has 4 pins on it)
Then on the other side, you will see the pins for the HDLED across from the PWR led. Then the Reset pins across the PWR BTN.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 29, 2008 | E-Machines eMachines Desktop PC
E-Machines (308714) Motherboard Logo
231 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
