Question about GPS
It randomly loses power while Im riding. Sometimes the power comes back automatically and other times it does not. Could it simply be the battery? Or one of the connections? Sometimes the problem starts after going over a bump but sometimes not. How can I know where in the problem lies. Thanks for you help.
  • 3,287 Answers
I had a similar issue with a Garmin V mounted to the handlebar of my ATV using a RAM mount. I wonder which GPS you're using and how you're using it?
After determining that it only happened on the shock-prone ATV while riding trails, suspicion turned to the internal batteries. You didn't note your GPS model or application so I don't know specifics for your problem - but I wouldn't feel uncomfortable suggesting that it is an intermittent power connection. If the power source is an internal battery, batteries or battery pack; check the batter compartment for dirt, debris, etc. Clean completely. Next, inspect the terminals. These must be clean and corrosion free. They are often pressure sensitive connections - meaning they rely on squeezing the batteries together and press in the battery's top and bottom to get the + and - voltages to the GPS.
If the springs or clips that provide this pressure have become weakened - it is very possible that physical shock to the GPS could cause a momentary loss of power. This would result in a brief loss of display followed by a 30 sec to a minute or so for the GPS to boot and get a "fix" again.
Adjust or bend the clips or springs as needed to create greater pressure on the batteries. Some battery compartments reply on a hinged door to complete the battery circuit. make sure that when the door closes the springs are pressing down on the batteries instead of being bent off to the side with significantly less pressure.
If you can't get these suggestion to solve the problem - you could try to use an external power source to power the GPS. This would remove the entire battery, compartment, springs, etc from the "loose connection" part of the equation. This only works if the GPS offers an external power connection - like my Garmin V (and many others) GPS does. Unfortunately, most of the strictly hand held or trail GPS devices do not offer an external power jack for this purpose.
If you have other questions or need additional help, be sure to tell me which GPS you've got, what your application is when it fails and how you're securing it.
I hope this helps and good luck. Please rate my reply. Thank you.
Posted on Apr 07, 2011
98 Saturn RUNS GREAT BUT SOMETIMES WHEN I STOP AT A RED LIGHT OR USE MY FLASHERS & WINDOW WIPERS I LOSE POWER. MY RADIO WILL LOSE POWER I HAVE 2 ACCELERATE 2 GET MY POWER BACK. WHAT CAN I DO 2 FIX IT?
Sounds like you have a short to ground and bad component like a wiper motor drawing too many amps, dirty/loose grounds or power connections at the battery or simply a failed battery or alternator
Jul 03, 2015 | Saturn Cars & Trucks
Turn Key and Loses Power
When a vehicle goes completely dead if a large drain is placed on the electrical system, such as starting it, the problem usually lies either at the battery connections or where the cables connect to the vehicle. Slamming the door repeatedly is probably just jarring the loose connection back and forth. Start with this, usually the fix to a big problem is smaller than you think.
Feb 23, 2014 | Hyundai Motor 2004 Sonata
Screen zoomed in zoom out
this is likely a virus, trojan issue... have you done a thorough virus scan with current software???
superantispyyware.com... free
Aug 17, 2013 | Sony Computers & Internet
My ti-89 will turn off randomly when i use it. I have changed the batteries multiple times and it still does this. sometimes it will turn back on with the previous screen if i hit the on button a couple of...
The calculator has an automatic power down (APD, a trademark of TI) feature that makes it turn itself off to save battery life. If you press the ON button, the last displayed screen is restored.
Feb 18, 2010 | Texas Instruments TI-89 Calculator
My 2000 Ford Windstar LX is randomly losing all power & shutting down for 2-5 seconds while driving. Everything stops working ( like theres no battery in the car ), then it comes back and starts right...
If you just had your battery replaced recently before that, Either your positive or negitive terminal is probably loose and needs tightened. It may get jarred around, and do that shutdown your 2-3 times, until something jars it to a better connecting position.
Oct 10, 2009 | 2000 Ford Windstar
Check engine light comes off and on 2004 Honda Accord, and sometimes lose power and then starts riding fine again; I just had it hooked up to diagnosis and can't find the problem
Sometimes losing power because there is not a correct air/gas mixture. Your car need a close to 14.6:1 ration to be perfect.
This ratio is maitaining by ECU, only if the ECU gets the correct signal from your O2 sensor. The O2 sensor is about 100 bucks. First to take off battery ground cable off your car for 1hour to clear out some error state. When putting back, if the check engine goes off for a while then coming back, replace the O2 sensor. Good luck.
Jul 06, 2009 | 2004 Honda Accord
1998 Honda CB750 battery dead sometimes for no apparent reason
sounds like a bad charging stator circuit.  May be a bad rectifier or voltage regulator.  You need a multimeter to check each component.  It also simply could be a bad battery.
Mar 11, 2009 | 1998 Honda CB 250 Nighthawk
1991 gmc sonoma random loss of power
could be the crankshaft sensor causing the timing to be off if it has a coilpack type distributor or if it has a gear driven distributor then it could be either the distributor itself or possibly just cap and rotor
Feb 13, 2009 | 1993 GMC Sonoma Club
Turns off randomly
Im asuming you are charging it up all the way. It is most likely a hardware issue, have you dropped it?
If its a software issue, your Bonned, Verizon wont do anything with that phone except replace it if its under warranty. And they usually find a way out of it by saying you got it wet or something. Check the contacts on the battery also, make sure ther not crusted up.
If the sticker on the battery is red, its got water damage and Verizon wont help you, if its white then its alright.
Hope this helped somewhat.
Oh, and if you take a shower and you have your phone in the restroom, the steam will collect moisture in the phone and eventually short it out. If so, unplugg the battery, take it apart and air it out for a day, you could use alcahol wipes to clean it, do this with the power connection port also, let dry and put back together, i have saved many of phones from water damage with this methode.
Feb 12, 2008 | LG enV VX9900 Cellular Phone
GPS Logo
52 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
