Question about Dynex Enhanced Wireless-G USB 2.0 Network Adapter
Bought top of the line netgear wireless router works great but my
Dynex Enhanced Wireless-G USB keeps freezing evey couple of minutes .Have tried reinstalling and plugging it into different usb ports.Dynex seems to be a piece of **** and looks like I will have to lay out more money?My wifes is runnining a netgear and is working fine,Im right next to it and it sucks.
Please help.
  • Anonymous Nov 08, 2008
    Same here.....no fixes?
  • Anonymous Feb 08, 2009
    Same issue - I have a laptop on the network that connects fine, but trying the Dynex Enhanced USB will not connect. It will show me available networks, I can see my wireless network, but even though I matched the connection config exactly, it will not connect. Apparantly there is supposed to be a lighted indicator on it - it is not lit. The fact that it can see the other networks tells me it is connected properly, and I updated to their latest posted drivers, and device manager see it without error. Stumped. Win XP with SP3.
  • 854 Answers
Possible reason why your computer is not getting online wirelessly is because the wireless settings on the router and the wireless settings on your computer do not match. Here are some troubleshooting steps that I suggest you try:
A. Checking the Wireless Settings of the Router
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on the Wireless Settings under Setup and take note of the SSID.
5. You may also change the wireless channel here. We suggest channels 1, 6 and 11.
6. At the bottom of the page, look for the Security Options. If in case that the security is set to WEP or WPA-PSK, we have to enter the same wireless security on all wireless PCs. To make sure of the key, we can try modifying the security. Please refer to the following:
For WEP: Select Key 1 and enter 10 hexadecimal digits (0-9 and A-F) on the empty box beside it. Then, click on Apply.
For WPA-PSK: Enter an alphanumeric key (minimum of 8 characters) on the Passphrase box and click on Apply.
Note: The Key and Passphrase are case-sensitive.
7. On the left pane, please scroll down and click on Wireless Settings under Advanced. Please make sure that the boxes for Enable Wireless Router Radio and Enable SSID Broadcast are checked.
8. Click on the Setup Access List button and uncheck the box Turn Access Control On.
9. Click the Apply button.
B. Connecting to the Wireless Network
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
We hope that the above steps provided would help resolve the problem. If the steps above did not work, we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Can your computer go online when it is hardwired to the router?
2. What wireless adapter are you using?
3. What is the operating system of your computer?
Posted on Aug 16, 2009
I have a Dynex Wireless G USB adapter. I don't think it works right. My wireless system runs on Linkyss and my signal is strong, but I can't get on the internet very well. My Dynex very rarely...
Move closer to the router and see if the situation improves. if it does the signal is just weak from where you are. if it does not I would uninstall and reinstall the device driver to see if that resolves the issue. May also try to change the wireless channel the router is set to, you may be experiencing outside interference on its current frequency.
May 21, 2011 | Dynex Enhanced Wireless-G USB 2.0 Network...
I have a Dynex router model 10/100m router. I hooked up a netgear Prosafe Wireless Access Point model wg302. I have wireless internet connection but I am unable to "secure" the line. I have...
Any wireless security settings are going to be accessed from the netgear. When you chain one device to another, you need to know what the IP address the access point is assigned in order to log into its web interface. the wireless options will be missing if you just simply log into the Dynex web interface. To figure out the APs address, you may have to manually configure it to keep it simple.
May 17, 2011 | Dynex 4-Port Ethernet Broadband Router...
Dynex card not keeping the computer online
it is a pure case of signal interference.check for any cordless phones with the same frequency range of the wireless router,,or any telephone line passing by.baby monitors,or any radio transmitters,walkie talkie,plz post me if it doesnt solve it,,also try upgrading the firmware of the router if it is a bit old.best of luck
Apr 18, 2009 | Dynex Wireless-G USB 2.0 Network Adapter
Tough issues with my Dynex wireless router. Please help!
Try to reset it to the factory specs and start all over again with install CD.
Mar 15, 2009 | Dynex Enhanced-G Wireless Broadband Router
Can't get it to work
I had the wireless working with dynex card before the virus hit the computer. The virus is fixed, but the internet does not work.
Feb 28, 2009 | Dynex Enhanced Wireless-G USB 2.0 Network...
Wireless signal keeps dropping/dissapearing
Check my tip
Using Router and Wlan adapter from different brand (Dynex + Belkin) is sometime calling for trouble: you must configure both to be sure to be on same standard (or change Both).
I'm using Netgear + Belkin and tune is not easy
On router config check radio power, reduce the used standard (B/G A/N) to the only one used by Belkin adapter (N).
Be sure you removed Windows zero wireless configuration (= use windows to manage my connection= OFF)
edit your belking wireless networking utility to automatic reconnect:
try downgrading to G standard from router side
Check your network connection plugging your laptop to router via lan cable.and check network params (DHCP DNS etc.).
Then check wlan connection near router, if you experience wlan drops only when far from router, find any possible interferences source (Microwave, cordless, remote) remove it or be ware you cannot have wlan when your wave is working.
Dec 13, 2008 | Dynex Enhanced-G Wireless Broadband Router
No connection with wireless router
Have you tried using an ethernet cable instead of a USB cable? USB connections for internet traffic aren't always the best.
If you can make the change to ethernet and then open your command prompt and type ipconfig /all and tell me what ipaddress,subnet mask, and default gateway it says.
Nov 16, 2008 | Dynex Enhanced-G Wireless Broadband Router
Software won't install
I would take the dynex back to the store.
I have dynex and a brand new netgear router.Netgear is awesome!
Wife has netgear and hers is working fine and she is running vista!
Im running dynex and nothing but problems so easy fix is replace with netgear.
Goodluck
kingelviss
Jul 16, 2008 | Dynex Enhanced Wireless-G USB 2.0 Network...
Dynex Wireless Enhanced G Router -- Lost Password
You'll need to login to the router and reset the wireless key.
May 30, 2008 | Computers & Internet
DYNEX Enhanced Wireless G Adapter USB freezes up WINXP
hello!
your may try the ff:
-- run antivirus and antispyware
-- try a diff usb port
-- uninstall and reinstall updated driver of your adapter
-- make sure your computer usb port is 2.0 or if the adapter is backward compatible with USB 1.0 or USB 1.1 compatible
May 05, 2008 | Dynex Enhanced Wireless-G USB 2.0 Network...
Dynex Enhanced Wireless-G USB 2.0 Network Adapter Logo
261 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
