Help! I am replacing the master/slave cylinder assembly in a '94 Jeep Wrangler. I have located the bleeder screw in the new assembly, however there is no screw! In the old assembly there is an allen screw, should I be using the old screw? Purchased the part from a dealer, called them back with this question and they didn't know!
Any help is greatly appreciated.
This is not a bleeder hole, this is a weep hole like in a water pump to see when there is seepage past the seals.
Bench bleed the system. With the master cyl. line and slave cyl assembled, place the master cylinder in a vise, fill the master cyllinder. actuate the slave cylinder back and forth lower than the master cyl. This will allow the air to escape upwards back into and out of the master cyl.
Once bled the system can be installed.
Good Luck
I am also having a huge issue with this cylinder- the new slave cylinder has a bleed hole on the side and not where the bleed screw goes(?) You can not bleed because it is sealed................HELP!
