Is it supposed to be water in the air filter compartment
    Brigadier General:
  • 4,736 Answers
A little is Ok. A lot of water isn't. If it's no more than a little condensation, you're safe.
Posted on Apr 07, 2011
I need help with my whirlpool ref water filter replacement.
Need more info on what type of fridge it is. Side by side with the water filter at the bottom with the push button on the left. Push it really hard and the filter ejects from the housing. Or if it's in the ceiling or top of the fridge inside the fridge compartment. You lower the cover, then lower the filter (will still be hooked up) then grab the filter with with both hands. One in the back to twist and the other on the front to keep it stable and in place. If you twist from the back and don't hold the front. It will snap that plastic that the filter goes into. Which we don't want to happen. After yiu replace the water filter. Make sure you dispense at least 1/2 a gallon or a full gallon of water out or the water dispenser to get all the air out of the water line. Having air in that line can and will cause a bunch of other issues later on.
Hope I was a little helpful my answer.
Oct 07, 2016 | Whirlpool Refrigerators
Filter on a Whirlpool WRS965CIAE is jammed. Filter is supposed to pop when filter housing is opened. Any suggestions? Thank you.
The filter should auto eject as you open the filter door.
However, maybe the cartridge is weighed down by water still in the cartridge. Try shutting off the water supply line and drain out any remaining water in the system at the dispenser.
Try closing it and reopening it- make sure that portion of the compartment didn't freeze up.
If you have a putty knife or something similar- perhaps a bit of persuasion with the putty knife- jiggling the filter will help release the cartridge.
Mar 04, 2015 | Whirlpool Dryers
Chev Impala Air ducting leaks water to the passinger side floor compartment when it rains
Open the hood, remove 2 plastic pins & cover just below the windshield on passenger side. There should be a preformed long rubber gasket that diverts any water away from the cabin filter (regularly replaced) found underneath in the compartment & sometimes the rubber becomes dislodged when changing the cabin filter.
May 22, 2013 | 2005 Chevrolet Impala
How to replace " cabin
The 2001 model Aztex has 2 cabin filters, they usually come 2 to a box when you buy them.
The charcoal carbon filters are the best.
Removal:
•Open the IP compartment door.
•Remove the rear inside IP compartment door.
•Open the HVAC module assembly access door
•Remove the RH passenger compartment air filter from the HVAC module.
•Slide the LH passenger compartment air filter to the HVAC module opening.
Remove the LH passenger compartment air filter from the HVAC module.
Installation Procedure:
•Install the LH passenger compartment air filter into the HVAC module opening.
Slide the LH passenger compartment air filter toward the left side of the HVAC module.
•Install the RH passenger compartment air filter into the HVAC module opening.
•Close the HVAC module assembly access door.
•Install the rear inside IP compartment door.
•Close the IP compartment door.
I Hope this information is helpful.
Sep 03, 2011 | 2001 Pontiac Aztek
Hi, I have a 2003 Kenmore Coldspot refrigerator. It has started leaking water on the inside from the top(where cold air blows) into the bottom of the fridge. the model # is 106. 73192302. The serial # is...
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Hope this helpout.......
Jul 29, 2010 | Refrigerators
Water pressure is at a trickle in door dispenser on fridge. filter is clean and mounted properly.
Check the water reservoir in the rear of the fresh food compartment. It may be frozen. If so, there may be an issue with the "damper control assembly" (located in the upper left side of the fresh food compartment) that allows cold air from the freezer compartment into the fresh food compartment. This cold air works its way down to the reservoir (and perhaps other items) and freezes the water inside the reservoir, which disallows regular flow of water at your external dispenser.
Contact an appliance service company.
Feb 19, 2010 | Frigidaire FRS26H5AS Side by Side...
Car is making funny noises and wont accelerate
I had this problem also after i washed my car engine compartment, water in spark plug compartment causes this problem. remove the wire plugs from the spark plugs and dry the compartment/spark plug sockets, also open the air filter compartment and make sure it's dry and clean. also do not forget to inspect your spark plugs also, install new ones and your car will run like new! Good Luck
Feb 08, 2010 | 1994 Toyota Corolla
Water filter location on 22cuft side by side.
The most likely area for the filter on a Jenn-Air is inside and top right hand corner of the fresh food compartment. A Jenn-Air model number looks like this JSD2388AEW Send me your model number and I will send you a Service Manual, Thanks, Sea Breeze
Jan 16, 2010 | Jenn-Air Refrigerators
Where is the water filter located on the Samsung SRS2028CSS
The water filter is located in the
upper right-hand corner of the fresh
food compartment.
1. Remove blue bypass cap and
retain for later use.
2. Remove sealing label from end
of filter and insert into filter head.
3. Rotate gently clockwise until
filter stops. Snap filter cover
closed.
4. Reduce water spurts by
flushing air from system.
Run water continuously for
two minutes through
dispenser until water runs steady. During initial
use, allow about a one- to two-minute delay in
water dispersal to allow internal water tank to fill.
Sep 10, 2009 | Jenn-Air JFC2089HT Bottom Freezer French...
Runs, but nothing comes out
Check the filters and the fan blade it may have come loose. Do you still hear the motor running? Get me the model number on the unit. Sorry it took so long to get back to you I have been sick the past few months.
Aug 30, 2008 | Bemis 526 300 Humidifier
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
