Question about SanDisk Sansa e260 MP3 Player
While charging it gives battery is too low system shutdown
    Novelist:
  • 151 Answers
Try charging for at least 4 hours when it is switched off.
Posted on Apr 07, 2011
Liebert gxt2-10000t230 low batt,bypass light flashing,no output,shutdown after a minute
Test outlet power by switching the unit to manual bypass and breakers off.
If power is supplied OK and the filter board repaired OK then restart the unit starting with the breakers supply to unit,battery confirm the display is on and static bypass led also on then switch back the bypass knob to normal and press the on button to switch the unit to normal.
Give the batteries time to charge 12hours then you can test the unit on backup mode.
Nov 25, 2014 | Liebert (GXT2-10000T230) (GXT2-10000T230)...
I connected 8, 100Ah battery with APC 2.2KVA inverter, now it doesnt give correct battery indication and keep producing beeping noise, whats the problem?
Continuous Beeping (theamber On Battery LED will be illuminated)
This alarm indicates that the UPS has reached aLow Battery condition and will soon shutdown. The UPS can only operate onbattery for a limited amount of time. In order to protect the unit's batteriesfrom discharging too much, the UPS will shutdown and turn off its output. Towarn you that the unit will soon shutdown, the UPS will sound this alarm 2minutes before actual shutdown. With optional Powerchute Plus software, 2minutes can be changed to 5, 7, or 10 minutes to give you more of a warning ofimpending shutdown. If you hear this tone, you should immediately gracefullyshutdown your operating system to prevent data loss or corruption.
Note:This graceful shutdown will occur automatically if Powerchute PLUS software isbeing used.
Constant, Solid Tone (the red Overload LEDwill be illuminated)
This alarm indicates that the UPS has detectedan Overload condition. If this alarm is sounded, try removing non-essentialequipment. The alarm will remain until the load is reduced. To determine ifyour UPS is capable of handling the equipment you want to protect, visit APC'sSizing Guide at www.apcc.com/sizing.
Continuous Beeps for One Minute; RepeatedEvery 5 Hours (Replace Battery LED will be illuminated)
This alarm indicates that the UPS has failed itsSelf-Test of the battery. The unit will continue to sound this alarm until theunit passes the test. Try to let the unit charge for a few hours and thenperform another Self-Test (Press and hold the on/off button until the second'chirp', then release). If it fails and the unit is still in-warranty (twoyears from date of purchase), then contact APC. If the unit fails and its outof warranty, then order a replacement battey cartridge through your reseller,distributor, or from APC's web site.
Apr 21, 2011 | APC Computers & Internet
Acer aspire 2920z is automatically shutdown only message appear warning critical battery low and then shutdown
Sounds like your battery is faulty and not charging. Try replacing the battery or just use the mains lead with the battery removed. If this keeps happening replace the system board
Feb 23, 2010 | Acer Aspire 5610-4648 Notebook
Battery is to low system shutdown
charge it smarty. if it wont hold a charge take it back to store!!!
Aug 25, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
My dell precision m65 battery does not get charged at all... Even though i charge it, it shows only 12% of charge n says low battery... Kindly advice me what could be done...
If your battery is not charging there could be two reasons for the same . First the battery has exceeded its lifetime and requires a change or is faulty
Second your ac adapter is not giving enough charge to charge the battery.
Open the battery health meter , by pressing the Fn+ F3 key on the keyboard . check if battery reports any error message.
Shutdown the computer and disonnect the Ac adapter and the battery and press the power button for 10 seconds
Reconnect both the Ac adapter and the battery
power on the system and tap on the f2 key slowly on the left side of the screen , look for the option that says battery info.
Check what is the status of the Ac adapter and is the battery showing charging.
if the Ac adpater shows as none, then adapter needs a replacement otherwise the battery.
Thanks for using fixya
proton
Aug 15, 2009 | Dell Precision M65 Notebook
Not charging when it says charging
I was going to suggest a recalibrate might do this
with some machines run the battery to flat then fully charge at full charge shutdown and reboot windows.
With some machines the same thing is done as follows:
Enter the bios and disable the automatic shutdown for low battery. Disable the automatic shutdown for low battery in Windows. Run the laptop until it just dies from the battery going dead.
Charge the battery. Re-enable the automatic shutdowns.
And I believe some even have options in the Bios to recalibrate.
If this doesnt work then could be a voltage issue in the charger (is it universal with voltage settings?)
if it is this and no settings that could have been moved to wrong voltage etc, then maybe need testing and replacing.
Hope this helps
Jun 10, 2009 | Dell Inspiron 6400 Notebook
2001 Lincoln LS electrical system SHUTDOWN
change the drive belt and have the voltage regulator in the back of the alternator checked out and also check for any draws on the car anywhere cause this can cause the alternator to over charge trying to keep the battery charged up
Jul 13, 2008 | 2001 Lincoln LS
"Battery Is Too Low System Shutdown"
The battery has come loose from the contacts on the inside.
Remove the back (4 screws), remove the battery and put it back in securely.
Then charge it for a couple hours.
Best of Luck.
Nov 14, 2007 | SanDisk Sansa e260 MP3 Player
Cant charge
maybe the battery is dead try replacing the battery of the player.
Oct 01, 2007 | SanDisk Sansa e250 MP3 Player
Dell c640 laptop battery
Normally that is the best way. Turn your system on and let it run down without the power cord. It will shutdown automatically when the battery is really low. Then with the system off, connect the power cord and let the battery recharge. I'd let give it at least a 10 hour charge if not overnight. Should be OK by then. When you power back up the next day, look for the "icon" that lets you check power levels. That little program should tell you loads of information that you might find useful. Look for "hints' that will extend your battery life too. The newer batteries today no longer have that "Memory Issue" they once had. Just remember re-chargeable batteries do wear out over time. You can only recharge them so many times but that's now in the hundreds with the newer ones or around 2-3 years depending on usage.
Aug 26, 2007 | Dell Latitude C640 Notebook
SanDisk Sansa e260 MP3 Player Logo
49 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
