My laptop motherboard broke. i was advised by a friend to remove the hard drive and buy a cradle. i am having trouble finding the correct cradle for my hard drive it is a fujitsu model no mht2040at.part no ca06297-b33400sn. your help would be greatly appreciated.
  • 73 Answers
This or a similar External 2.5 IDE usb enclosure.
http://www.amazon.com/External-Portable-2-5-inch-Enclosure-Laptop/dp/B002AQ5DC2
Posted on Apr 07, 2011
How to replace my gateway laptop'hard drive model: w3501
you can replace it by using a compatable new hard drive.
Sep 17, 2011 | Gateway Computers & Internet
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          How to replace Acer Aspire 5630 Hard Drive
          The link below gives you the user manual. On the computer views is the base view which will show you the correct bay on the bottom of the computer. You will loosed the screws to that bay, remove the cover andl you will see the hard drive. Althought I have not removed this particular laptop hard drive, these drives usually pull up or back using a tab provided. The hard drive will probably have a cradle the actual drive is connected to. You will have to removed the old drive from this cradle and put the new drive back on the cradle exactly the way the old drive was attached,
          I hope that this information helps and gives you a place to start solving your issue.
          Brian
          Jan 24, 2010 | Acer Aspire 5630 Notebook
          Ide controller for dell inspiron 2500 laptop
          Any 20GB disk-drive has built-in drive-electronics,
          which interface with the IDE hardware on the motherboard of the laptop -- typically, laptops do *NOT* have "plug-in" adapters for such "basic" functions, unlike desktops, where you can change video/audio/network hardware via add-in cards.
          You probably can use any disk-drive that is _smaller_ than 32GB -- disks larger than 32GB require newer motherboards, due to the larger capacity of those disks.
          Dec 11, 2009 | Computers & Internet
          Hard disk doesnot detect
          Hi....
          If your hard drive will not be detected, be sure that your hard drive is connected correctly. Check you hard drive if it is plug in the power and the SATA or IDE cable.
          Have you experience having trouble by this error, DISK BOOT FAILURE.
          This is a hard drive problem witch is not correctly connected.
          If your hard drive are correctly connected, try yo first boot your hard drive in the BIOS.
          Hope it may helpful for you,,
          Thanks for using fixya
          Regards
          ICmanServer
          Aug 18, 2009 | HP 448337-001 - HP 520 Series Intel...
          SATA hard drive issue
          Try changing the SATA controller to run as IDE. I can not advise anthing other because you have not listed the model of the gigabyte board, therefor I can't download the manual to advise the correct setting.
          Jul 07, 2008 | Gigabyte Motherboard, GeForce 7100, Core 2...
          Sata drive will not fit
          This is clear that your laptop doesnt support SATA and will support only to the previously used type of HDD..
          Thankyou
          Jun 17, 2008 | HP Pavilion dv9000z Notebook
          How to replace the hard drive
          first lets get the basics out of the way, did you buy a 2.5" laptop harddrive? Good if you did.
          Unplug your laptop, turn it over, remove the battery, find the harddrive cover.
          In most dells its on the side
          example: http://www.buildorbuy.net/images/laptop_pics/3remove_screws.jpg
          if its on the side like that, remove the screws and in most laptops you have to pull it up to unlock it, now pull it out. some laptops might have a simple pull it out system, you didnt say witch one you have so i cant be sure.
          If the hdd is not on the side then its on the bottom
          example: http://www.irisvista.com/tech/laptops/ToshibaM205/dismantle/big/Toshiba-Portege-M205-02.jpg
          you need to remove the old harddrive from the slot, remove the hdd cradle.
          install the new harddrive in the cradle plug it in. put the screws back on.
          Your done.
          Mar 19, 2008 | Dell Inspiron Notebook
          Hard Drive Replacement
          there are normally 2 panels underneath the notebook, you need to remove one or the other, normally the right hand side and then remove a protection plate and you will see the hard drive located in a metal sleeve holder, althogh you may need to remove the battery and the heatsink fan to get at the hard disk cradle. Simply slide the cradle away from the motherboard and the HDD should slide out.
          Sep 04, 2007 | Toshiba Satellite 1715XCDS Notebook
          Upgrade hd on laptopp
          The easiest way is to remove the casing under your laptop and see what make your drive is, but any make of laptop hardrive sould be ok. Sometimes the hard drive may be held in a cradle so you will have to remove it if this is the case and use it with the new hard drive. A problem comes when you probably have the Acer backup/restore folder on another partition(which sometimes includes Windows, as you don't always get a hard windows cd rom),on your current hard drive, so make sure you have a Copy of Windows otherwise You'll have to purchase another Windows installation disc, or clone your drive with something like Norton Ghost.
          Nov 24, 2006 | Acer Aspire 3000 Notebook
          Computers & Internet Logo
          David Payne
          David Payne
