Question about KitchenAid 24 in. KUDI02IR Built-in Dishwasher
KUDI02IRWH2 Kitchenaid won't drain - KitchenAid 24 in. KUDI02IR Built-in Dishwasher
  • 822 Answers
Drain is blocked
or pipe from drain pump.....
cheers
Posted on Apr 07, 2011
Kitchenaid KAWS700G will fill and wash but won't drain and spin
My washer also did not drain. I disconnected the power supply and water hoses and the drain hose and lay the machine on its side.. The motor is at the bottom. Once I disconnected the hose and put my finger to look inside. There is a rubber stopper and once I moved that aside and looked inside I found my baby sock stuck in the the pump. Once I gently pulled the sock out It came out easily. Lucky me the motor is in working condition.
My washing machine was manufactured I believe in 1997.
This is the first time ever took look under any washing machine.
Best of luck!
Apr 15, 2013 | KitchenAid Washing Machines
Dishwasher won't drain
the drain hose clogged, fix the clogged.
Jan 28, 2012 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid Dishwasher won't drain KUDI01ILBL6
Do you have an air gap on your sink? Check it to see if its plugged.
Nov 15, 2011 | KitchenAid Dishwashers
My dishwasher won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Jul 31, 2011 | KitchenAid Dishwashers
My kitchenaid kudv24 will not drain water out
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Jun 21, 2011 | KitchenAid 24 in. KUDS25SH Built-in...
My Kitchenaid model KURD25SHBL0 dishwasher is not draining. Drain line is clear, wash cycle runs fine, and there is no obstruction to overfill sensor. Can hear pump runnng during drain cycle but no...
Usually the wiring won't affect the direction of the pump turn. It is more likely that the fins on the drain pump empellar are damaged.
May 30, 2011 | Dishwashers
My dishwasher is filled with water and won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
May 07, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
Won,t drian the water.
Hi
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 21, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Water won;t drain out
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 28, 2010 | KitchenAid Dishwashers
KitchenAid 24 in. KUDI02IR Built-in Dishwasher Logo
97 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
