Question about Nokia E63 Cell Phone
My Nokia E63 is fully charged. But display is not coming (completely Blackout). I asked in gallary, they said IC problem. What exactly should be the problem ?
  • 29 Answers
Contact the service technician to change the display in your mobile.
Posted on Apr 07, 2011
Blank white screen on my nokia e63
1.try change screen
2.try full flashing software
3.check lcd ic
Aug 29, 2012 | Nokia E63 Cell Phone
My Nokia E63 is not turning on, I've changed the battery, charged it with a desktop charger, on other phones it will on but on my e63, I won't just turn on. what am I to do.
PHONE IS DEAD WON'T COME ON
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jul 05, 2011 | Nokia E63 Cell Phone
My nokia E63 mobile display is not working what to do
You may replace check and replace one or both of those EMI filter IC if tryiong to fix display problem issues on Nokia E63. Trace the each corresponding line paths first for a water damaged device before installing a Ne LCD display filter IC.
If still nothing happens then you need to get it replaced from Nokia store.
Feb 27, 2011 | Computers & Internet
Nokia e63 not charging problem
nokia e63 not charging solutions without ic
Jan 04, 2011 | Cameras
E 63 not charging folt
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 24, 2010 | Nokia E63 Cell Phone
Not charging phone
car problem is the MALWARE problem of the mobile, you need to reprogram your fon
Mar 05, 2010 | Nokia E63 Cell Phone
No display to indicate battery is charging Nokia E63
to confirm that the phone is charging, switch on the mobile and charge or turn on the mobile when it is charging.if it doesn't works then try with some other charger,still same there is some problem with the battery r the connection point.check with the vendor.they will definitely assist u.
Aug 19, 2009 | Nokia Cell Phones
Nokia E63 Cell Phone Logo
80 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
