Question about Fisher and Paykel DD24D Dishwasher
I have a Fisher and Paykel DD24D Dishwasher just installed and the fault code U keeps coming on, which says no water, I checked the water supply, it is try on, so now I'm at a lost.....thanks
  • Jacqueline Hohman Apr 08, 2011
    Hi Daniel,
    It's U1, I also forgot to mention the water source us turned
    on and there is water getting in the dishwasher drawers. It
    starts working for a little while and then the faulty code of a
    faucet with a circle and slash thru come on the led and beeps
    till I cut off the power source. It was just installed and has never
    been used......
    J.
  • 2,510 Answers
If the unit is new do not try fix it or have it fixed, or even look into it, call the dealer or take it back to him as you will invalidate your warranty if you do anything to the unit, and that is not worth it. Let the dealer worry about it.
Posted on Apr 08, 2011
  • 4,323 Answers
Hi
Please post back with the complete error code...is it U1 or U2 or... Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 07, 2011
  • Daniel Scott
    Daniel Scott Apr 08, 2011
    Thanks for your reply. U1 is a water pressure issue usually
    occurs due to kinked hose or the fill hose not properly installed in your case.
    Daniel
    Thanks for your reply. U1 is a water pressure issue usually occurs due to kinked hose or the fill hose not properly installed in your case. Hope this helps...please post back for further assistance.
    Daniel
Fisher & paykel IWL12 Fault code 12
Your water inlet valve is likely defective. The supply hoses behind the machine lead to the watervalve.
Jan 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
E6 fault unable to reset all cycle lights showing
E6 is "Flood switch activated."
Turn the water off and disconnect power to the dishwasher, then empty water from the inside. Clean drain well and check the drain hose at the back. If that does not work, then the water pressure switch is at fault. Call your Fisher & Paykel dealer or Authorized Service Center.
Dec 06, 2011 | Fisher and Paykel 24 in. DS603MFC Built-in...
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Looking for list of fault codes for dish drawer
I hope this is what you are after
F1 Flood switch has been
activated.
Turn the water and power supply to the
DishDrawer® off and call your Authorized
Service Center.
F2 Motor problem. Call your Authorized Service Center.
F3 Temperature sensor failed. Ensure water coming in through the inlet
hose is not hotter than 65oC. You may
need to install a tempering valve on your
water supply.
F4 Faulty temperature sensor
or element
F9 Electronics malfunction. Call your Authorized Service Center.
U1 Fill Fault 1 Turn the DishDrawer® water supply on.
2 Ensure the spray arm can rotate about
the center, and if the DishDrawer® is
full of water, it will need to be emptied
manually.
3 Call your Authorized Service Center.
May 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 fault on a ds603
The reason for your F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorised service centre. These problems cant be fixed on your own.
Apr 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F & P DD603 starts to wash then beeps & flashes U1 - Fill Fault. I have cleaned both drawers & replaced all parts correctly, still comes up with U1.
Have you checked whether you are getting the water supply to the dishwasher. Check if there is no kink in the water hose.
If no problem with water supply then check the water pressure rating is OK for the dishwasher.
Dec 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dishwasher is starting on its own. Will not stop Both drawers . Need help and approximate cost to fix.
Not sure if you are getting any fault codes on the display.
The most common problem is water getting on the base of the dishwasher.
Turn the mains power off. Extend the bottom drawer out as much as possible and dry the base with towels and hair dryer.
Water can leak if the drain hose is cracked or is kinked. Have it checked.
Nov 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
I keep getting a beep and believe it is a Fault Code
try turnning the unit of at the plug the the controll panel holde the program botton in and trun unit on try this on both draws
Jul 23, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher paykel dd603
Pull the bottom drawer out !!!!! To do this on the left and right sides of the bottom drawer you need to pull the pins (Plastic) then pull it out it has hoses still connected pull out and turn on side look in the back left corner (with Pwr off) there is a board there and it has a water (Flood sensor) on it make sure it is dry this is what the Fault code is
Dec 03, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel DD24D Dishwasher Logo
73 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
