Question about LG Dishwashers
Our dishwasher was working fine (about 3 yrs old). Woke up in the morning and went to unolad it. There was a small amount of water in the bottom and it does not respond. No power, lights, nothing. I checked the breaker and it had not tripped. Any suggestions?
    Master:
    Sergeant:
  • 385 Answers
First turn off the breaker. Once you have the power off, take off the bottom panel.You will see where the electric wire comes into the dishwasher, it should have a small cover over the connections.Take off the cover and you will most likely find that one connection came apart. Be sure to clean up the wires and use new wire nuts and be sure to use electical tape over them.
Posted on Apr 07, 2011
I woke to water draining from the dishwasher this morning. I looked inside and there was water in the bottom? Help?
when you say you woke to water draining i assume the pump was activated if so you water valve is not shutting completely causing your dishwasher to gradually over fill this will cause your water level switch to activate the overfill stage and bring in your water pump have a close look and if this is the case replace water valve hope this helps let me know how you go
Nov 14, 2009 | GE PDW7380NSS Stainless Steel Dishwasher
Water does not drain from the bottom. I understand that a small amount is normal, however, this is not a small amount. Thanks for your help.
It worked for me .I have a danby countertop dishwasher.
I took off the metal top
I looked under on the left side to find the pump
I took both hoses off the pump and took off the little fan.
i took off the little metal bracket behing the little fan. and unscrewed the little pump to take it out.
the little metal piece that the fan was on wouldn't even move.So i sprayed it down with wd and it started moveing again then a screw fell out.so i found where it went(inside the motor which the fan and metal piece move) got the tweezers and replced it. oiled it some more and put it all back together. Perfect.
May 24, 2009 | Danby 22 in. DDW396 Free-standing...
Water left in bottom of dishwasher after cleaning
I suggest checking the drain and screen. There is most likely a little clog in there. If there is even the slightest amount of clog, the washer will not finish the drain cycle.
May 23, 2009 | Dishwashers
3 yrs old model; worked fine then no lights on front panel
i hate to tell you this, but more than likely the circuit board behind that light has gone bad. It is a costly fix at several hundred dollars, and this isn't the first one i've heard that has done this...
Mar 13, 2009 | Bosch Evolution 300 SHE43M0 Built-in...
Frigidaire fridge door makes a loud popping sound
You need to take the door off the hinges and remove the lower hinge plate from the bottom of the door. This is where I found my popping problem. The black bushing with the 3 bumps and dips on it is loose in the plate going into the door. I took black eletrical tape and rapped it around the part that goes into the plate to tighten the bushing up so it wouldn't turn anymore. ( This was a temp fix to see if the popping would go away) 3 Weeks later and still working. If the sound comes back I will put some double sided sticky back foam on it. Both doors were doing this on my fridge, and now its as quite as a mouse. I hope this fix works for you.
Dec 29, 2008 | Electrolux Frigidaire Professional Series...
Milky liquid residue on washed dishes
This sounds like hard water spots.  Use Jet Dri or a similar product to reduce it. Use the recommended amount of detergent.
Nov 15, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher was leaking; now gets "stuck" 3 minutes after starting
You're describing a number of issues related to old age and maintenance. First, you've likely got a mechanical timer that is getting stuck. If the price of replacement is outside your budget for an old warhorse....
Second, in come cases, the timer takes care of water level...in most, however, there is a float or aeneroid level sensor. If it is a float...it may be clogged/jammed with detergent or debris. Located in the wash tub near the front. Clean it up. If it is an aeneroid, it has a tube going from the tub to the lower part which hooks into a 3 inch or so flat sided round item with two wires coming out. With the power off, test it by blowing and sucking on the tube. Blowing into it should open the switched leads ...sucking should hold a 'vacuum'. The pressure of water opens and closes this switch to determine water level.
Jul 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Arms are not spinning
If the spray arms arent clogged up then you have a clogged filter.
Please Rate this !
Jun 23, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Indesit Dishwasher
disconnect the drain hose and lower it into a bucket if no water comes out there is a blockage in the hose/pump.
Jan 25, 2007 | Indesit 24 in. D63S Free-standing...
Dishwashers Logo
270 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
