Question about Whirlpool Kitchen Ranges
Some liquid has gotten spilled between both glass panels. Need to find out how to clean inbetween the glass.
    Sergeant:
  • 176 Answers
Open the oven door and you will see screws in the door, remove them and it will come apart. I did this before, but it has been a while, but I was able to clean.
Posted on Apr 07, 2011
Can't find bad odor
You probably don't want to hear this, but here goes: usual cause of this is from spilled liquids that have gotten under or behind inside panels of fridge. Other most common cause is from something nasty getting into the motor/compressor area located in lower back of unit. Most people don't know that the compressor area should be cleaned about once a year. Good luck with your fridge.
Jul 02, 2012 | Refrigerators
Tip
How to Clean Scanner Glass
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
I spilled liquid on the HP 5610 scanner. Now I have a stain on the left margin of my scans. The stain is a strip that extends from top to bottom. How do I remedy this?
One way to remove all types of stains and fingerprints is Windex and a soft rag. That is one of the cheapest and easiest way to do it.
A better approach to it is to use monster cleaner. It is a special spray to clean tv screens, laptop screens, and even windows. It comes with its own cloth that works amazingly well. I have used it for years and has worked for me every time. You can pick it up at your local Best Buy or click on the link to buy online. http://www.bestbuy.com/site/Monster+Cable+-+TV+Screen+Cleaning+Kit/5774879.p?id=1069297113224&skuId=5774879&st=screen%20cleaner&cp=1&lp=1
May 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Code f2E3
It appears that this code is a code for "keypad spill" so it somehow may have gotten liquid inside the keypad. It may be as simple as removing the face panel and wiping clean the keypad and putting it together, or you may end up needing to purchase an entire keypad and installing.
Mar 08, 2011 | KitchenAid KESC308LSS Electric Kitchen...
I spilled some 7up on my dsi, my dsi's R and L buttons weren't working and so my cousin ripped them off(against my orders) So i spilled the soda on it, without the R and L buttons. Now it won't turn on,...
the problem is this, the liquid you spilled on it has gotten into the panel and has therefore caused a real mess of both your panel and device.this is common to all electronic devices, the only way out is if you can take it apart carefully and try to use a piece of cloth soaked in methylated spirit to wipe the entire board clean(methylated spirit dries faster and evaporates other liquids like your 7up which is probably still on the board causing damage).if this doesn't work, the only way out is to give it to an engineer or call the company because the liquid might have caused a short circuite and damaged the whole board beyond repairs.
here is an instructional manual on how to open it:http://www.youtube.com/watch?v=Q8RFuyiEATo
Oct 25, 2010 | Nintendo DSi White Console
I need to clean the inside of my remote control.
If it is dirt/dust etc then it won;t hurt it. If you spill a liquid on it then that is another matter. Depending on what was spilled it may be already to late to save it. Certain liquids such as coke contain acids that eat away at parts. Even if it is cleaned very quickly then the contact pads under the buttons may suffer damage and your buttons won;t work.
Basically you can disassemble to remote and clean/rinse with distilled water only. Then let dry for a few days and put it back together. Even tap water can contain things that will attack the parts inside so you need distilled water. A good bottled water will do.
9 out of 10 times the remote gets junked either from the spill or from the cleaning.
Oct 11, 2010 | Televison & Video
Removal of front glass panel
The glass is not removable, due to safety reasons when the unit is being used.
Feb 07, 2010 | Maytag MMV5165 Microwave Oven
Cleaning Oven Door Glass inside face
First take the two inside screws out, (found at the top of the door) they will pop out when you have both sides off so make sure to take them all the way out so you dont lose a washer or one of the screws. The handle is actually secured by these 2 screws and will come off of the door when you remove them.. your metal door can bend slightly in this process, so be careful. as soon as the handle and screws are off you can clean inside of the 2 pieces of glass, also a good time to clean off the opposite side of the door behind the handle. only take the 2 screws off no need to remove the full door. I used a magic eraser to remove the grease and then I cleaned the glass with glass cleaner. I used a small vice to secure the door when putting the handle back on, but you could have someone to hold the piece togeather for you too. (I have a frigidaire stainless steel model)
Nov 09, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Glass door force4@optonline.net
First remove the door. (on this model I think you open the door part way and pull up to remove it from the hinge) Set the door so that the handle and glass are facing down. Remove the four screws from the bottom and two screws from the top the whole door should just pull apart after that.
NOTE: Make sure you look at where all the trim and stuff is sitting before taking it apart.
Good Luck
Nov 03, 2008 | Frigidaire FGF337EC Stainless Steel Gas...
How to clean in between glass on oven door
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
I would recommend looking at those exploded views.
Sep 19, 2008 | Jenn-Air JMC8130DD Microwave Oven
Kitchen Ranges Logo
112 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
