Question about LG WM-2277HW Front Load Washer
Help ! We have an L G front Load washer model # WM2016CW that leaks soap out the front bottom of the dispenser. It is 2 years old and I have followed all the manufacturers instructions on using HE soaps and the amount. This problem started about a month ago and does not happen with every load but it does happen at least every three to four loads. I do laundry everyday as I have 4 very active children plus my husband and I . Any suggestions ?
  • LG Master
  • 8,220 Answers
You can remove the dispenser and place it in the dishwasher for easy cleaning.
I have included some notes on your washer and I have a service manual for you HERE
Posted on Apr 07, 2011
Wcvh6800j1ww leaking under soap dispenser
Three screws at the back of cover, three screws at the front, push the cover back and you can remove it. 1 screw at the front of the soap drawer and two more on the dispenser and you can lift the whole unit up.
Sep 24, 2012 | GE WCVH6260F Front Load Washer
I have a Frigidaire Gallaxy Series top loading washing machine, 4 years old that seems to be leaking from the bottom. Is this something I can fix myself? THANK YOU.
Before you buy a new $100 door gasket, pull out the soap dispenser tray and look inside the washer where it normally sits. If there is significant soap accumulation (even 3/8 inch), the water can become backed up and trickle down the washer front to the door bottom, making it look like a door leak. Fixed mine this way.
Jul 30, 2010 | Washing Machines
Kenmore front load washer is leaking water from soap
We had a similar problem with water coming out of the soap dispenser when the washer was run. I assumed that it was a problem with the water draining as everyone else posted here. I took off the front panel, got rid of the junk and drained it. Although this was great, it did not solve the original problem. It turns out that there was a sock stuck in between where the water comes out of the soap dispenser and in to the main compartment. Pulled it out with a needle nose plier and good to go. Thanks to everyone for their input here.
May 28, 2010 | Kenmore HE2 Plus Front Load Washer
Frigidaire gallery series front load washer leaking water on side where soap dispenser is. Have had two different repair places take a look at it- replaced soap dispenser- still leaks - repair people can't...
turn down the water pressure on the water line to the washer if the water pressure is to high it will splash out of the filler. there should be a vale on the main water line to the washer.
May 19, 2017 | Frigidaire Gallery Supreme Series...
LG Model WM2016CW Front load washer is 1 year old. It quit today. No power---NOTHING happens. Any answers??
Same thing happened to me
I freaked out
Then I emptied the water basin, on the front of the machine near the bottom. then it started up and worked
Feb 22, 2010 | LG Washing Machines
Water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Dec 15, 2009 | Miele Touchtronic W3033 Front Load Washer
Soap leaking out of the bottom of washer
highly likely if you didn't use your shipping bolts when moving your tub cracked bottom of soap dispenser inside of washer buy warrnnty sear about 250.00."less soap plz"
Nov 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WATER LEAKING FROM FRONT BOTTOM
try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
Jan 22, 2008 | GE WBVH6240F Front Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
LG WM-2277HW Front Load Washer Logo
503 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
