Question about AT&T 955 Corded Phone ( att00147  )
I am having problems programing my att 955 phone I have followed the directions and still have no luck
2 Suggested Answers
consultel1
  • 860 Answers
SOURCE: my ATT 955 phone had a powerfailure and now the
Sounds like you'll need to setup the intercom number again.
Assign an Extension Number to Your Phone
Press program.
2 Press the down arrow until the screen displays EXTENSION NO, then press the right arrow.
3 Press the down arrow or the up arrow to select the desired extension number (from 11 to 22).
4 Press the save button to store your selection.
NOTE: If you duplicate an extension number, you will hear a repeating
short ring. Repeat Steps 1-4 and assign a different number (from 11 to 22).
Posted on Jan 29, 2010
Where can I find a book on the different UVerse Remot tv codes for a new tv?
Hello
Universal remote code for Panasonic TV/VCR/DVD combo is
0437
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Dec 19, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
How to program speed dial
Directly from the manual for the ATT 822:
Storing numbers:
1. Press Line 1 or Line 2
2. Lift handset or press SPKR.
3. Press PROGRAM
4. Dial the telephone number you want to store. If you want to include a 3 second delay, press PAUSE where the delay is needed.
5. Press the memory button where you want to store the number. You will hear two beeps to confirm that the number has been stored correctly.
Good luck !!
Jul 12, 2010 | Lucent AT&T Speakerphone 822 (21213)
My ATT 955 phone had a powerfailure and now the alert won't *******. It rings constantly.
Press program.
Jan 29, 2010 | AT&T 955 Corded Phone...
I have a 974, 945, and 955 phones in a 2-line office. I am getting a squeal on the intercom when I call just one phone. It works fine between other phones. It worked for 2 years and then the squeal showed...
Check the battery on all the phones then make sure they are all programmed with different extension numbers. If the battery has been dead and you have had a power outage then it may have reset the phone to factory default extension 11.
Dec 03, 2009 | AT&T ATT-974 Corded Phone
PUK CODE BLOCKED MY PHONE LG VU CU920 HOW DO I UNLOCK IT
If you have an account on att.com you login then click on PHONE/DEVICE, then click UNBLOCK SIM CARD then follow the directions on that page. If you dont have an account Like Me you can go to an att store or call the help line at 1-800-331-0500. Same thing happened to me yesteday and i just got my LG Xenon yesterday. Hope I help. Message me if i do. ^^
Jul 18, 2009 | LG Vu CU920 Cellular Phone
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to helpme@att.net, and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Apr 04, 2009 | Televison & Video
Conference calling directions
Downloaded manual. Thanks for your offer of help. Happy problem is solved.
Jan 05, 2009 | Panasonic ATT-Lucent 955 Technologies...
I have ATT U-Verse and the LG LFD790 Home Theater System. I can program the U-Verse remote to turn the LG on/off, but can not control volume from U-Verse remote. Do you have any codes I can try?
well you have the right code, but you have to get the volume options so you can control it. Hold down at&t and the ok button, then let them go. put in code 955 then press enter(bottom right) now you should be able to select whatever device and control that volume source
Dec 30, 2008 | LG LFD790 System
Panasonic KX-TG9341 (purchased 9/10/08)
I believe the problem is not the handset phone but the telephone line because the phones were working for a brief period again last night. As I said, ATT is supposed to send a repair man out today to check the lines. If the repair man says the problem is not the telephone line, I may contact you again. Thanks/
Nov 03, 2008 | Panasonic KX-TG1033S Cordless Phone
AT&T 955 Corded Phone ( att00147  ) Logo
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
