Question about Whirlpool Duet GHW9150P Front Load Washer
Duet is filling up with water when not in use.....opened the door of it this morning and got my feet washed....also never finishes a cyle......stops about every minute and has to be restarted....very discouraging
  • Whirlpool Master
  • 8,220 Answers
Remove the bottom panel and check the filter. If it is a bad water valve which it could very well be yall can access it from the top.
.Duet is filling up with water when not in - themobilian_2164.jpgthemobilian_2165.jpg
Inside the base panel is a tech sheet that will help for diagnostics. I have a service manual for Duet to help with replacing components HERDuet is filling up with water when not in - themobilian_2166.jpgg src="http://i.fixya.net/uploads/images/themobilian_2166.jpg" alt="themobilian_2166.jpg" class="h_mi" />
Posted on Apr 07, 2011
Water slowly runs in washer when it isn't on
dirt or faulty inlet solenoid diaphragm
simple fix is to turn the tap off at the wall when finished
Jul 18, 2017 | Whirlpool Duet GHW9150P Front Load Washer
During wash or rinse cyle, water leaks from the bottom
open the door,check the rubber boot for any holes,ussually that's where it leaks,also wipe the inside of the door,i've found hair and lint stuck on the inside bottom of the door and water leaks out but pull open the rubber boot and run your fingers all around it to check for any holes.you can remove the bottom panel and then run the machine to see where the leak is coming from.
Apr 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet front load washer fills randomly with water when not in use and the door is open. Usually it only fills up to the door opening but this morning it was over flowing. ??????
check and make sure you do not have a siphoning problem. make sure the drain isn't backing up in the machine. This could also be a problem with the water inlet valve. Its possible that its not closing all the way when the machine is off. If its dirty water entering washer then the problem is siphoning from the drain. If its clean watet the valve is bad.
Feb 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Power is on, still will not start
Too many clothes
washer door not opened between washes
low power/extention cord
kinked hose
Door not shut tightly
hoses connected backwards
inlet screens clogged
circuit breaker tripped
unbalanced load
excessive suds
wrong detergent
Repair Manual
Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9100LW1 fills up with power off
You have a faulty fill valve
If you want to check which one, try turning off the cold supply only before you go to bed
If the washer has water in it next morning it is the hot valve that has gone faulty if it is dry then it is the cold one
They are easy to change and can be bought from a number of suppliers
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet frontloader washer's dispenser stays filled
I had a similar problem, but mine was with the detergent side. I removed the top of the washer and had to clean the dial that advances to let the cyle of dispensing continue. It worked, but now the machine shakes and I am told is 'unbalanced'
Jan 16, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Water fills up in machine when off
HI thanks for your question. i would replace the water valve, its not shutting off completly. replace the valve, thats where the hot & cold water go .
Oct 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
