Question about Sharp AR-C160 Color Copier
We have a sharp AR C-260 and we have a H5-01 error however i cannot put in the # * c * code any ideas?
  • Sharp Expert
  • 316 Answers
H5-01. 5 Continuous POUT not-reached error
perform the following procedure to enter the simulation mode.
#-interrupt-c-interrupt-14-ready key
Posted on Aug 18, 2011
  • 87 Answers
SOURCE: error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
Posted on May 09, 2009
  • 990 Answers
SOURCE: error code h5-01
Hello sir; the paper exit sensor get stock, just put back in the track let it moved free.
Posted on Apr 14, 2009
  • 62 Answers
SOURCE: sharp ar-m350u error code h5-01. How do I fix
vheck this link out http://www.fixya.com/support/t1570580-remove_h5_01_error_code_sharp_arm550n
Posted on Apr 15, 2009
  • 6 Answers
SOURCE: error code h5-01 appeared on my sharpmar-507
You had 5 jams in the fuser. Clear the jams first. Make sure all sensors are clear. You may need to reset the thermoswitch on the fuser. You will need to remove the fuser to do that. Next press in sequence within 7 seconds #/P Int C Int buttons, then 14, then copy start, yes on the LCD. The copier should recycle and be up and running. Good luck.
Posted on Dec 27, 2009
  • 4 Answers
That is an easy one. That code means you had 5 jams at the POD1 sensor.
1) press #,*,C,*(enter simulation mode)
2) press 14, print, CA(clear all)
Should reset the copier to a normal state.
Posted on Aug 31, 2010
H5-01 Error, I need to clear this. How do I enter tech mode, I know the sequence is P# - * - C - * - 14 - start - execute. Its a sharp AR C 260
Did you open the left door and clean all the paper out of your fuser and exit area? If you cleared paper and code and get it again either your fuser needs a rebuild or your transfer belt if not moving paper through fast enough. H5-01 means five consecutive attemps to send paper through the fuser have failed.
Aug 03, 2010 | Sharp AR-C260M All-In-One Printer
Sharpe ar-163 with error code u-240
Hello sir; The error code you display is CRUM communication error.
Feb 05, 2010 | Sharp AR 163 Copier
Sharp ARM-160 I have an error code L4-11.....any ideas?? Thanks
Please verify the continuty of the LAZER UNITSand the POLLYGON MOTER is.The problem in pollygon moter
Nov 02, 2009 | Sharp AR-M160 Laser Printer
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code h5-01
Apr 14, 2009 | Sharp AR-M350U Copier
Sharp AR-405 error code F1-15
Hello sir; this error code means " elevator motor "problem inside the finisher,check it out is something stuck the motor. or you have to replace one.
Feb 16, 2009 | Sharp AR-M205 Copier
Error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
How do i clear error code on AR BC-260 H5-01
I don't have that error code specifically but any error code that starts with an H has to do with the fuser section of the machine. It could be the thermistor, rollers, or the heat lamps.
It should be looked at by a Sharp technician to determine the correct problem.
Oct 01, 2008 | Sharp AR-M237 Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-C160 Color Copier Logo
192 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
