Question about Keurig B60 Coffee Maker
Coffee grinds overflowing on top of k-cup - Keurig B60 Coffee Maker
    New Friend:
  • 3 Answers
If coffee grounds are flowing out of the filter basket into your cup then the basket lid isn't being held tightly enough by the brewer lid. There is a simple $3 fix kit on ebay for this... and it's guaranteed:
http://www.ebay.com/itm/EASY-FIX-STOP-LEAKING-COFFEE-OVERFLOW-FROM-KEURIG-PODS-MY-K-CUP-FILTER-BASKET-/271684395896?rd=1
Posted on Dec 27, 2016
  • Keurig Master
  • 43,501 Answers
Check the bottom needle...it is plugged...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 08, 2011
Water and coffee leaks out of spout on second cup
it sound like you have some blokage why don't you give it a service ferst also check if the coffee is to fine it may cos this problem
Mar 12, 2016 | Breville Coffee Makers & Espresso Machines
Our coffee maker overflows,coffee grinds get in coffee and overflows.
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Ensure that the coffee machine is sitting level on the counter.
Jul 11, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Coffee maker with grinder--sometimes, when percolating, it overflows
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
Jun 28, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
My cuisinart brew and grind overflows onto to the counter also
8. Clean your carafe and machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water spots). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
Jun 27, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cusinart 12 cup grind and brew overflows with grinds and water
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Over flow grounds without a cause
I have had two of these machines (warranty return) and they both did the exact same thing. Here is what I have discovered the problem to be.
The lid for the carafe gets stick and internally jams. As another poster suggested clean it thoroughly (this sometimes works). I have another solution. Call 1-800-726-0190 and explain that you lid jams and leaks all over your counter. They will send you an new lid for free no questions asked. They obviously are very aware of this situation and don't even ask for proof of purchase or purchase date.
Jan 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Over flow
I think you have to be careful in how much water you put in. I had the same problem the first few times I used it. I started to only fill until the water just met the 10 cup mark, not over it. I have not had the problem since.
Dec 30, 2007 | Cuisinart Grind and Brew 10 Cup Coffee...
Keurig B60 Coffee Maker Logo
823 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
