Question about Dell Computers & Internet
When listining to sound from website for ex: tv programs, there is echo and sounds is far away, how to fix this problem, thanks in advance
  • Dell Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 07, 2011
Philips shm1900 headset on Lenovo thinkpad t430 with windows 7
It sounds like you are still using the mic on the laptop. Because you are far away from it, it sounds like echo.
Make sure the phillips headset is selected in the Windows mixer.
Make sure you are plugged into the mic jack on the laptop.
Make sure the mic is not muted. This is a default setting.
Apr 02, 2014 | Philips SHM1900 Headset
Lost instructions for my dav-hdx285 dvd home theatre sounds great when the dvd is used but when using sound from the tv sound is not nearly as loud and if i have the volume on the tv up it sounds like a...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-DAV-HDX285-Home-Theater-Systems-manual/id/23316bh343/t/2/
The TV and process the sound differently so the echo is a just a time smear. You shouldn't actually need to augment the HTS speakers with (ugh) TV speakers.
As far as comparative TV-sound loudness goes, if you drew it from the Cable Box to the audio system I'm sure it would be the same as your other audio. TV
Feb 21, 2011 | Sony Bravia DAVHDX285 Theater System
I have a brand new paramax p-510 home theater system that has a low hum when the sound is turned on from an appliance ie-Tv etc. when the sound is turned off about 20 seconds later it stops. It doesn't...
here is your answere.... if you have your tv or vcr, or dvd...etc to close it can cause a hum with a "indoor antenna "..... now we can fix this .... move your antena far away as possable from the tv...etc make sure wires are not "tangled" in it, make sure that your source inputs are not grounded, ex 3 prong plug on vcr on tv...etc. invest in a good surge supressor that will " clean your power " ex ... monster cable etc... now you can " ground the system " by using a alagator clip to your "cooling fins" and connect a wire with a loop ring to your outlet that is grounded or loop all devices together and then to ground. if you still have any isues consult a licenced electrician to check your ground from pannel box to meter and make sure the ground is "bonded" to the neutral bar... this should solve your issues....
Dec 27, 2010 | Audio Players & Recorders
Volume on Bluetooth
Truthfully get a better headset these are NOT great and always seem soft and echo a bit... Motorola make the best.
Mar 17, 2010 | Plantronics Explorer 220 Bluetooth Headset...
ECHO/REVERB in SINGLE Player campaign Battlefield BadCompany
I know what you're talking about, the echo is to make the game more realistic.
Mar 06, 2010 | EA - Electronic Arts Battlefield Bad...
TV sound issue - randomly goes mute
there is finally a downloadable patch available on the corp website that can be pulled into a portable drive and installed directly into the tv.
sound isssue fixed with the software update
Sep 21, 2009 | Samsung SPN4235 42 in. Plasma HDTV
The sound on my Acer aspire 5515 has an echo.
Go into the control panel to sound and audio - click advanced (toward the bottom) + check that your speakers are set to Laptop Stereo.
Post your results here, especially if this doesn't fix your problem...
Mar 24, 2009 | Computers & Internet
Sound echos
Turn the sound down or off on the TV remote and only use the surround sound....
Mar 03, 2008 | LG DR787T DVD Recorder
Computers & Internet Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
