Question about Turbos, Nitrous, Superchargers for Mercedes-Benz C230 Sedan
I got a 2002 C230 K coupe,,, it happend occationally when i accellerate the car feels like it got hick ups, like its choking and at high revs it sounds like there is a suction noise,,,,almost like when you **** Air throw your teeth....could my Kompressor be faulthy or maybe a leaking hose ??? please
I have the eaton suppercharger in my garage that came from a car just like yours'. brand new.
Posted on Dec 03, 2011
Is it normal for the revs to stay up when changing gear in a 2002 4x4 3.0L turbo diesel navara?
do they revs drop off when taking pressure off accelerator pedal when out of gear? if only staying high during gear change it would suggest a worn clutch friction/pressure plate so the engine isn't slowing down when clutch is depressed .I'd also have the OBD codes read to see if there is a sensor/switch at fault , but sounds like the clutch to me
Jun 21, 2014 | Nissan Navara Cars & Trucks
Hi! I have xr200 2002 model. No problem at start and idle. But when I throttle mid high to shift gears, I notice a loss of power and feel that the carb not giving enough gas. When I rev high to overtake,...
If your vehicle is fitted with a choke try releasing it, it controls the amount of fuel going to the carb, let it off the give it the throttle mid ride
Oct 23, 2013 | 2004 Aprilia RS 125
Good afternnon, I have a landrover 110 diesel 1987 the engine wont rev initially but if you hold down the accellerator it will slowly pick up.After engine has reached high revs when you remove your foot...
Its possible the fuel lift pump is faulty. remove the fuel filter, if you see that its half full of fuel, then this will tell you the pump is at fault.
There is a lever on the fuel lift pump, turn the ngine till you feel itgo harder, then feel the travel of the pump and if it is firm or easy to operate.
Lift pump failure is common on these.
Sep 21, 2009 | 1994 Land Rover Defender
Shift problems with 94 eldorado touring coupe
I'd check & lube all kickdown cables in the area of the throttle body, as well as follow any to transmission and lubricate well there too. It almost sounds like something may be seized and holding into lower gear.
Aug 19, 2009 | 1994 Cadillac Eldorado
1976 Gran Torino motorcraft 2150 2bbl carb. Starts and runs ok at high revs but as choke eases off and revs decrease, engine stalls. Fuel pump OK. Float levels and choke pull off OK. No obvious vacuum...
Are you sure your idle ports ( size of pinhole) in carb aren't plugged with something? What happens if it starts to die, and you give it a quick squirt of WD-40 , down throat of carb?
Oct 17, 2008 | Ford LTD Cars & Trucks
Engine cuts out
Maybe when you went into the ditch you partially pinched your fuel line so now your not getting enough fuel to the motor?Crawl up under your car and see if you can see any damage to the fuel lines, or anything else...filter etc.
Oct 02, 2008 | 1997 Nissan Sentra
Turbos, Nitrous, Superchargers for Mercedes-Benz C230 Sedan Logo
133 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
