Question about Magic Chef Refrigerators
My ice maker stopped working a couple days ago..it had been fine until then?
  • 4,070 Answers
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Posted on Apr 07, 2011
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
The ice maker stopped working, gradually over a 3 day period.
It sounds like your harvesting motor failed. If you feel comfortable working on it, you can pull the ice maker out and remove the harvest motor and have it replaced. If you don't feel comfortable pulling out the harvest motor, pull the ice maker and replace the whole unit. They are a little tricky getting them out but if you take your time and don't rush, it is a doable fix for the typical do it yourselfer
Jan 11, 2018 | KitchenAid KSRB25FRBX Aluminium Side by...
Ice maker has stopped working. It was fine 3 days
check water valve or icemaker valve is at the back of the unit
Apr 07, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Aug 07, 2008 | Jenn-Air JSD2789GES Side by Side...
Ice Maker
check the temp inside the frezeer it should be 0 degrees at all times if is higher then that then lower temps and clean condenser coils . if it is zero then repl entire ice maker the thermostat inside ice maker is not closing when it should and in return takes longer to cycle ice.
Jul 03, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerators Logo
148 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
