Question about Casio DB360G-9A 30 Pages Telememo Watch
How do i set the sweeping hands as i have set the digital element ok
Sweeping 2nd hand sticks at the 47 second mark
Possibly the hands are touching or the sweep hand is touching the crystal
Oct 29, 2009 | Invicta 8928A - Two Tone Blue Automatic...
Diddo
To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it.
Jul 03, 2009 | Citizen Eco-Drive BL5184-56L Wrist Watch
Have an Invicta Lefty Quartz Chronograph. The subdial that marks the minutes fails to reset to 60, though the large second-hand resets perfectly. Recently I bought another Lefty and had the same problem. I...
Actually the sweep arm can be set to 0 and will probably have to be every time you have the battery replaced. To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it. Make sure to set the right time and replace the crown in the time position.
Great watch!!
May 09, 2009 | Invicta Lefty Chronograph Watch with Band...
Second Sweep Hand Stopped
sounds like the gear that turns the second hand has a tooth missing.
Apr 28, 2009 | Watches
I have an Invicta 5103 mechanical wind chrono and the large second hand will not zero out on the 12
Dec 02, 2008 | Invicta Dive/Sport - SPEEDWAY CHRONOGRAPH...
Rolex ad Daytona 1992 replica
The advice given here is accurate to a degree. When wound, a rolex daytona IS running. However, it is the running seconds hand in the small sub-dial that is actually running. In the earlier Daytonas, this sub-dial was at the 9 o'clock position on the dial, (pre-2001 series daytonas). The later daytonas, from 2001 on, use the seconds at 6 position for counting seconds. The main sweeping second hand on the watch dial will NOT start until activated by the pusher at the 2 position. That pusher needs to be unscrewed and then pushed to start the large sweeping second hand. This action, in turn, starts the remaining 2 sub-dials in motion, counting minutes and hours. To stop the chronograph function, you push the pusher @ the 2 position again, to stop the sub-dial hands from counting, and then push the pusher @ the 4 position to re-set the dials to their "straight up position". This stops the chrono's function, until it is needed again, BUT the main running seconds, (at either the 9 or 6 sub-dial position, depending on the year series of the daytona) will continue to run, thus keeping accurate time.  Hope this gives you a better idea of how the timekeeping of the chronograph function on a Daytona works. So, to start your seconds running you need to start the chrono function by pressing the pusher at the 2 position. That will allow you to see the large sweeping second hand I think you're referring to here. Hope this has helped.
Doug
Jan 11, 2008 | Rolex Daytona 116520 Wrist Watch
Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Oct 09, 2007 | Watches
Casio DB360G-9A 30 Pages Telememo Watch Logo
128 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
