Question about Refrigerators
My ice maker does not despence ice - Refrigerators
  • 4,059 Answers
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
Posted on Apr 07, 2011
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
Ice maker sticks and it stops giving ice.
Does it stick when it is trying to despence the ice from the tray? The bracket the slides the ice out of the tray may be broken. If the bracket is just getting stuck it means that your ice is sticking inside the tray due to the teflon coating being worn out. Replace ice maker
If you need assistance on how to install the icemaker or a place to order one please feel free to contact.
Jul 27, 2011 | Kenmore Refrigerators
The ice in the tray melts and runs out the despencer outlet.\r\nMakes ice but the front part of the ice tray slowly melts and water runs out the despencer outlet. Have had service man work on it four...
Your freezer temperature is not coldenough, inspect for hardness of frozen foods. Make sure that the temperature is 5 degrees Fahrenheit or lower. Carefully feel the side of the ice maker if itis warm the unit is stuck in heat for release mode. Check and replace control module.Call repairman to check this.
Thanks
Feb 05, 2011 | Electrolux Refrigerators
Hotpoint refridger ice maker not despencing ice or water
my ice maker stop making ice there is ice cubes in the tray but the ice maker does not dispence the ice
Apr 04, 2010 | Hotpoint HSS25GFP Side by Side...
Ice maker leaks water into holding container, frezzes up holdeing container, ice wont despence , because its froze
sounds like your ice maker has a degraded coating on the mold that forms the cubes. if you remove it from the freezer, then you can see if the coating is coming off. if so then you need to replace the ice maker.
Jan 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Icemaker will not fill with water but water comes out despencer
Check the ice maker first by filling with tap water. Let freeze and if it cycles and dumps the dual water control valve on rear is defective. If ice maker does not cycle then I think you have a problem with the ice maker. Thanks, Sea Breeze
Look for that model number.
Dec 16, 2009 | Whirlpool Refrigerators
Ice maker in freezer fills up but won't dispense ice cubes. Also, there seems to be a large build up of ice under the dispenser
some ice makers have heating elements in the trays to melt the ice away. that way it will despence.element could be bad.
Jul 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ice maker isn't getting enough water to it. and cubes are hollow
Most ice makers have an adjustment for the amount of water to despence.It is located under the cover of the ice maker
Jun 25, 2009 | Refrigerators
Frost and ice on flap of ice maker
look down in the chute where the ice despences see if its closing all the way
Feb 15, 2008 | Freezers
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
