Question about Casio EXILIM Card EX-S770 Digital Camera
Dark pictures camera was dropped and now all pictures are dark and fuzzy in the lower right corner, also all outdoor (sunlit) pics look like a negative. Is this fixable?
  • neovenki Aug 18, 2008
    i have the same problem .when i take pics in sunlight it is so fuzzy
I have a similar problem. Indoor pictures are ok but outdoor ones are bright and washed out like as if it is getting too much light. Tried to reset to defaults but no help. Suggestions ?(bobmelnick@hotmail.com)
Posted on Aug 31, 2008
Orange tinted faces
CCD FAILURE !
actually when it starts it starts like this pics with red or purple shades , noise ,distorted, blurred pics , discolored then it goes completely black
dont worry just call Sony for free repairs it is a manufac fault in thousands of cameras with different brands just call sony about ur problem PLS RATE ME FIXYA for help
Sony has issued service advisories for these problems
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
see this
http://www.imaging-resource.com/badccds.html
Apr 08, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Sony DSC W50 Camera - Trouble with Flash
Hi, I guess you are using the automatic mode ( not the "P" mode).
You should enable flash only when there is insuffient light. If you use flash in broad day light, your pic will be whited out. If you dont use flash in dark or low light, your pic will be dark or very dark.
So, when it comes of dark, try enabling the flash. If its still dark, increase the flash compensation (the eV value). If its still dark, increase the ISO number.
Hope these help.
cheers,
Sep 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
My Sony DSC-W50 just started taking dark blurry pics...
same here. had my camera about a year and a half when this started
Mar 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
A small dark blob, exactly circular, translucent, fuzzy outline, which is on every pic.
Same problem here too! dark spot and what looks like dust appearing on all pictures. Comes into sharper focus on extreme zoom.
Feb 24, 2008 | Ricoh Caplio R6 Digital Camera
Dark spot
The iris may not be opening fully or a leaf of it is sticking.
look in the front at you take a pic. do all three open evenly.
Jan 29, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Night time pic mode
The one thing I have noticed about the DV179, is that it takes poor quality photos and video, unless it is in pure sunshine... :)
Yes, zooming in does distort the pic's, so be sure to put the stabilization mode to 'on', this does help a bit.
Dec 27, 2007 | Jazz DV-179 Digital Camera
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Dropped camera-two corners dark
Check what the actual pictures look like when they are downloaded to PC or to print. The problem may only be on the screen. It may be very expensive to replace the screen, but you might be able to live with it?
Good Luck
Oct 25, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Indoor Photography
what's probably happening is this: Since the light is low, the shutter must remain open for a relatively long time. If you're hand-holding the camera, you'll get blurry shots. Using a tripod will eliminate this. It doesn't typically happen outdoors because there's usually enough light to permit very fast shutter speeds (>60th of a second or so). Some newer cameras offer image-stablization for those lower-light situations. The camera or lens makes very quick adjustments to compensate for your moving when taking a shot. Hope this helps! Best wishes
Sep 13, 2005 | Sony Cyber-Shot DSC-P1 Digital Camera
How many pics can you take with a digital camera? After 1200-1500 pictures my C2500L says funny then using the autofocus. It's still working fine, but I'm a bit worried about it. And what about...
Take a look at this discussion of shutter lifepsan. http://www.dphoto.us/forum/archive/index.php/t- 4531.html To summarize these posts, average number of cycles (one instance of open and close shutter) is somewhere between 50,000 and 150,000 cylcles. As one poster pointed out, we seem to take more pictures with digital than with film cameras, so a hundred thousand cylces might not be that many. I have a c2500L bought used at online auction and have probably taken about 1500 pics so far. Don't know how much previous owner used it. It's amazing how many pictures you take when you don't need to spend money on film and processing! The c2500L is a really nice camera and I hope that mine lasts many years. My c2500L is an early one with version 1.0 firmware (later models have version 1.20 sticker on side) and was built in about 1999 I think. As for autofocus, mine works great as long as I have the focus mode (regular, macro, super macro) and zoom level set correctly for my distance to subject. Fortunately, the green focus indicator lamp near viewfinder flashes when focus isn't right. A few other thoughts on focus: taking picture through glass, in mirror, or scene with no contrast (like a solid grey sky) might require you to use the manual focus or focus lock modes. Window glass fools camera, which tries to focus on glass instead of your desired subject. For mirror, you need to double the normal focus distance (measure distance from camera to mirror, focus on something twice as far, then lock focus and take your pic in mirror). With SLR film camera, mirrors and glass don't cause trouble because you are focusing manually. One other note on fuzzy or dark corners on pictures: if you use filters, especially a thick filter like a polarizer, you should probably get a 43mm to 46mm adapter and use bigger filter. At widest angle zoom, my polarizer causes vignetting in corners because the filter actually is "seen" by lens in corner of pics. Oops, I should have thought of that before buying filters I guess. Hope this helps some.
Sep 06, 2005 | Olympus Camedia C-2500L Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
113 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
