Question about Health & Beauty
I have a MZ moskito 125R.. the matter is.. the engine coil doesnt charge the battery.. i have to charge battery manualy before riding.. i have change the icbox khuttup and the engine coil but it seems like it was the wiring problems.. can any1 please giv me the drawing of my scooter wiring..
dromtonpa
  • 40 Answers
SOURCE: wiring for pride rally scooter.
Sorry but your probably going to have to get this to a service technician. That is a big problem you have there. Most wiring is`nt even color co-ordinated so it`s not a matter of matching up colors. I`d call a professional,
Posted on Apr 03, 2009
SOURCE: MZ CHARLY Scooter w/defective controller; can not find part
I have a manual for a 2001 mz charly electric scooter. The scooter folds down and you can carry it. Just checking to see if we are talking about same scooter. The book if have has the circuit diagrams.
Posted on Jun 21, 2009
  • 491 Answers
SOURCE: draw on battery when car on
First disconnect the battery overnight just to make sure the battery is not self discharging......if it's dead or down in charge while disconnected....time for a new one.
Now.....if the battery is good....disconnect one battery cable and place a 12 volt test light between the cable and the battery post the cable had just been attached to. A bright light means a drain in the car.
Your job is to remove one fuse at a time until the light dims.
A dim light is OK...clock memory etc.
Remember....a open car door is a drain......the dome light.....so keep them closed while pulling fuses.
Also....if the fuses don't show a drain......disconnect ALL wires from the alternator....there could be a drain there.
Just keep disconnecting one thing at a time until the light goes out or dims.
Posted on Aug 12, 2009
SOURCE: battery want charge... ok i paid to talk w/ a
Have an 18 hp b&s intek engine on riding lawn mower. Have new battery,new starter, and new solonoid and will not start after the tractor sits overnight. Occasionally it will start right up with a jump.
Posted on Mar 22, 2010
SOURCE: Daihatsu Leike scooter just not cranking
late reply but in case other users need help with this, i had the same problem with my LEIKE LK 125 GY-2... Normally there sucking pipe to the carb comes loose or falls off... Just reconnect it :) Jamie
Posted on May 10, 2010
MZ TS 150 Clutch cable replacement. Has anyone got a diagram or instructions please
Hi, Mark for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your MZ, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How To Change Motorcycle Clutch Cable Transworld Motocross
MZ TS125 TS150 CLUTCH CABLE ORIGINAL MZ 13 29 003 eBay
MZ Motoralkatrsz webruhz
https://lazic.info/josip/manuali/mz/ETZAllHysEng/ETZAllHysEng.pdf free service manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 06, 2017 | MZ Motorcycles
I have a craftsman riding mower model 247.288810. While cutting my lawn the engine all stalled and would not start anymore. I changed the spark plug and the battery is new, what could it be?
there are 3 safety switches,clutch,deck and seat, Craftsman 247288810 Lawn Tractor Parts
take the cover off so u can access the coil,unhook the black wire from the coil,not spark plug cable,try to start it,if it starts then a safety switch is bad,if it doesnt,then jump the solenoid,if it starts then it is the seat or clutch switch,if you want to bypass safety switches,connect a switch to the ground and coil
Jul 28, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Why doesnt my light on my mz76 charger light up?
Get a digital volt meter and test out the voltage on the battery.
atdlee@netzero.com
Jun 01, 2014 | Metz NiMH Battery 76-56 for 76 MZ-5...
Battery will not take charge, but can jump start and it runs, but does not keep charge
Possible charging coil under the flywheel issue, or with the retifier, there is a tool called a negative shunt, this will quickly tell you if there is any charge to the battary from the engine
May 06, 2012 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
My 2002 Cr 125r won't start. While riding it
change your sparkplug bus use a BR9SE sparkplug
Apr 20, 2012 | 2002 Honda CR 125 R
Thomas train shows as fully charged however when trying to use it, music starts but then a clicking noise and train doesnt move
the music is run by three aaa batteries so that will work no matter what, did you reconnect the battery to the vehicle after charging it
Jun 25, 2010 | Peg Perego IGED1084 Santa Fe Train
Craftsman 24 kohler engine
there is no alternator on small engines it is called a stater which is usually on the coil all one unit with coil but does the battery charge on a battery charger the battery might be bad & wont take a charge let me know if i can further help thanks wade
Jul 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Soleniod
it doesnt matter how you turn it starter to large terminal battery and charge wire to other large terminal key wire to small terminal
Oct 12, 2008 | Garden
Health & Beauty Logo
62 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
