Question about Cooler Master (CAVALIER2BLACK) Power Supply
I have a 1998 chevy cavalier and my egr went bad where is it located on a 2.2 engine
  • 3,051 Answers
I purchased an EGR valve for my 2000 Cavalier and couldn not find it either. So I went to autoparts house and they looked to no avail. Then went to dealer who also could not find it. Hmmmmmmm, alas it does not have one. Why? Well, it is my understanding that certain government vehicles do not require one. Was mine one of them. I don't know. But I can tell you that all EGR valves are bolted to the manifold, and for cavaliers it is typically on the drivers side of the engine. Good luck with this one.
Not all cars have an EGR valve, government or not. It depends on the engineering designs of how cool the engine runs, and how much NOx is produced under load. If not a lot is produced in the first place, the converter would likely take care of it nicely.
some years makes models did not have one.
such as the 1992 3.8L engines for example
and others.
government has nothing to do with it. some of these engines with the pollution controls they were built with put out acceptable levels of nox and otrher gases low enough to not warrant the need of an egr valve.
Posted on Apr 07, 2011
What would cause the egr valve on a 1998 chevy suburban 4x4 5.7engine to keep shorting out ?
electronic egr valves primarily gm viehicals .employ a egr valve that is not operated by vacume at all .an electronic solenoid in the valve is operated electricaly by the ecm .diagnosting this type if egr valve require a special scan tool . sorry your probley off to the dealer pal.
May 06, 2014 | 1998 Chevrolet Cavalier
EGR Vacuum Solenoid, cavalier 1998 standard 2.2 lts.
I believe it is on the pass side of the head.(EGR) exhaust gas recirculator .it alows the engine to re burn left over fuel in the exhaust.unfortunately the pasage way gets cloged with carbon buildup causing egr failure.this is very hard to clean and should not be done by a novice DIY. some times SEAFOAM will clear it out if it is not compleatly cloged it is worth a try.
Jan 28, 2013 | 1998 Chevrolet Cavalier
Where is oil filter located on 1998 chevy cavalier 2.2l
The oil filter on the 2.2-liter engine is mounted on the side of the engine block between the firewall and the engine.
Sep 22, 2011 | 1996 Chevrolet Cavalier
Can u please tell me where the EGR valve is located on a 1998 chevy cavalier thank u
the egr valve is located on the drivers side next to the fuel rail. here is a picture of the valve
(1) EGR Valve
Jun 08, 2011 | Chevrolet Cavalier Cars & Trucks
1998 Cavalier 2.2L I'm pulling codes of PO404 and PO405 The First says EGR Flow CKT Range/Perf The second is a Circuit Low Input for EGR Sensor A. PO405 is a constant code while 404 came up only once, but...
In the top picture you can see egr adapter, three bolts, the egr valve mounts to adapter. Hope the picture gives you some orientation? You can see the 5 wire connector and wire colors. The bottom picture should be the egr valve.
Mar 17, 2017 | 1998 Chevrolet Cavalier
Just wondering where to locate the air filter in a 1998 chevy cavalier
Follow the big black tube from the engine to the front of the vehicle. It connects to a box and the filter is in the box
Mar 05, 2010 | 1998 Chevrolet Cavalier
Replace termostat in a 1998 chevy cavalier still run hot
Yes it does have a electric fan, mine went out on my 2003 and I just changed the electric motor itself. Autozone offered the entire fan with motor or they offered just the motor. I chose to replace the motor only because I knew the fan blades and housing was fine. I had to drop the fan down and take out the entire assembly from the bottom but overall the process was a 3 out of 10 on the difficulty.
Mar 16, 2009 | 1998 Chevrolet Cavalier
DTC Code of a 1404 , and also a IAT High input malfunction
sounds like the IAT is disconnected, it is either in the flex hose from the air cleaner to the engine or in the air filter housing, on my GM product car it is in the air intake hose, it is small and has a 2 wire connector to it, just pushes and pulls in and out of the flexible air intake hose.
Mar 13, 2009 | 1997 Chevrolet Cavalier
1998 Chevy Cavalier-electical
youve either got a bad connection at the new battery or the power wire is shorting out did he have too pull the cables too get them too fit?
Feb 26, 2009 | 1998 Chevrolet Cavalier
Computers & Internet Logo
250 people viewed this question
Top Cooler Master Computers & Internet Experts
Computer Links
Avishek Samaddar
Avishek Samaddar
Chris Larocque
Are you a Cooler Master Computer and Internet Expert? Answer questions, earn points and help others
