Question about Toro Titan ZX5450 (54") 25HP Zero Turning Radius Lawn Mower 74832
My toro mower will not start now after it has sat all winter
  • 577 Answers
Make sure you have spark..pull plugs and roll over and look for blue spark, next smell for gas or see if plugs are wet....if they are wet its flooded with old gas which is not very combustable, remove air cleaner and put spark plugs in and spray some carb cleaner in the throat of carb and see if it fires, now if that works then you may have to check the needle and seat and the solenoid on bottum of carb if either one of these are stuck you will not get gas to the carb to run, hope this does it for you! don't forget to reply !
Posted on Apr 08, 2011
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
Toro recycler lawn mower
if old gas was left in the engine a good carb cleaning will need to be done
May 11, 2012 | Toro Power Lawn Mower
My Toro Z4200 will not turn when i engage gear on my right hand, machine sat all winter in my garage, replaced battery, which i can understand, but why did the hydro-gear on right side quit working just...
Make sure the hydraulic transport bypass is not open. It may be that your belt idler is sticking for the drive system. Check under the machine and see if all the belts are tight. You might need to grease the idler arms.
See a local dealer like www.arcolawn.com for diagrams and parts.
Good luck
Mar 13, 2011 | Toro Lawn Mower With Toro Power Tools
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
Apr 25, 2009 | Toro Lawn Mower With Toro Power Tools
Mower
If it sat for some time without running aslittle as 30 day the fuel is probly stale and needs to be drained and the carb cleaned and possibly a new spark plug
Jan 31, 2009 | Toro Blowers Rake and Vac - Electric...
Toro Titan ZX5450 (54") 25HP Zero Turning Radius Lawn Mower  74832 Logo
274 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
