Question about Little Tikes Toys
I need to take apart the log cabin and was wondering if you could tell me how to do it. moving 6 hours away and unable to move it all together.
2 Suggested Answers
  • 100 Answers
SOURCE: Replacement door for little tikes log cabin
Click on this link it is the replacement site link for little tikes. http://www.littletikes.com/consumerservice/replacementparts.aspx You should be able to click on the product you are looking for a replacement part for and you should be able to find it there.
You can email them and ask for the part that you are looking for as well here is the email address link http://www.littletikes.com/consumerservice/Contact-Us.aspx
Thank you
Posted on May 03, 2010
I am unable to get the feed dogs to lower/ I cant get the button to move anyway/
Make & model of the machine? Are you talking about the machine in the picture? Those models have no frame, and are infamous for having problems. If you take it apart to move the drop feed lever, there's a good chance it won't go back together and work properly.
Mar 03, 2015 | Sewing Machines
Hi, "Santa" was nice enough
Starting at the wood cut tower moving clockwise. Tower is 6. 6 to 7 to 8, L2, 9, L4,10,L5,11,fits into tree trunk, 14, (12 connects to the junction) 1, 2, (joins to 13 from the log over.) L5, 3, L4, 4, L4, 5, connects to 6, the tree tower.
The logging tower rails. Connects from 4 to 18, then the tall tower, the rail, the small tower, 17, L2, 16, L4, 15, the tall tree tower, 14, L4, 13 and that connects to No. 2.
L2 is the lowest support. L4 is the middle size. L5 is the tallest.
Jan 23, 2011 | Toys
Can't figure out how to set the times to turn power off/on.The metal trippers seem to be permanently in there.
Remove dial from body of timer.
So now the timer is apart in 2 pieces.
Silver ON trippers and brass OFF trippers can be removed.
Place trippers in times you want timer to operate.
OFF trippers have to be at least 2 hours apart.
ON trippers have to be at least 2 hours apart
Minimum on-off function is one hour
Snap timer back together.
Tripper rotates around with dial.
When tripper contacts on-off lever, it physically moves lever like turning on light switch.
ON tripper moves lever one direction.
OFF tripper moves lever opposite direction.
Manual E-1020
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/e1020%20-%20english.ashx
Dec 11, 2010 | Heavy Duty Intermatic Wall Switch Timer...
HOW SET TIME ON AND OFF
You posted under intermatic 1020 timer
If this is not your timer, add a comment
How to set timer.
Rotate dial around until current time lines up with mark
Dial rotates with passing time.
When tripper contacts on-off lever, it physically moves lever like turning light switch on-off.
Manual E-1020
Dec 11, 2010 | Intermatic Timer E1020, Single pole/single...
Citizen watch secondhand not moving
its a solar watch meaning you have to completely charge the watch under artificial light for 24 hours or full sun for 6 hours
Aug 01, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
After reassembly blade will not cut wood, does not maintain suffient tension despite being correctly inserted
It sounds like the blade is not going through the guides properly if the blade is being pushed away from the wood.
Your blade is facing and moving the right direction, I am assuming.
Apr 17, 2009 | Saws
The laser light on my black & decker bdl500 stopped working
I had the same problem with mine. I took it apart and inspected it. Mine was a loose connection and after some fiddling with the wires the laser came back on. Put it back together and haven't had a problem with it since. Hope it helps.
Jan 09, 2009 | Black & Decker BDL400S Bullseye Crosshair...
Little tikes log cabin wall and door cracked in move
If the wall holding water is your concern, drill a large hole in the bottom of the wall where it meets the ground . Then, water will not collect in there.
If you are concerned with pinching little fingers then use a small amount of silicone caulk on the cracked areas and let it dry in the sun for about 12 -24 hours.
Let me know if you need anything else!
Oct 08, 2008 | Little Tikes Picnic On The Patio Playhouse
Computer recieved the blue screen of death but before....
turn it on with a/c and remove battery if it starts normal then the problem is from battery (TRY IT I HAD THE SAME PROBLEM)
REPLY THANKS
Jul 17, 2008 | Sony VAIO PCG-K35 Notebook
Toys Logo
291 people viewed this question
Top Little Tikes Toys Experts
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
