Question about Intel D845GVSR Motherboard
How do I get access to broadband. I have all the modems, ethernet cable links that work on another machine, but when I plug the ethernet cable in to my Emachine with a D845GVSR motherboard, I get no link or recognition. Any help would be much appreciated
  • Peter Calhoun
    Peter Calhoun Apr 07, 2011
    Please post the model and serial number of the Emachine. That will be more helpful than the motherboard. Thanks.
  • Intel Master
  • 27,725 Answers
If you need an ethernet driver or it might be something else
If you are trying to connect through a modem/router the ethernet driver should have come with a motherboard disc or the one supplied by your ISP internet service supplier
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps
Posted on Apr 07, 2011
Can not connect wireless to internet
verify that the cable are conned correctly. now the ethernet cable that come from the cable modem do not need to be plugin to the port that is label Internet, it need to be plug in any port 1 to 4. then access you router via a ethernet cable and setup the router of wireless access.
Jan 13, 2012 | Linksys Wireless-G Broadband Router
Need to connect modem to two computers so one computer can access work vpn.
Depending on how you set up the first computer, you can have one computer connected by USB and another by ethernet (straight-through cable). If you want both computers connected by ethernet, you need a crossover ethernet cable between the Modem and a router or switch (hub). You will need a straight through ethernet cables from the router to each computer.
Then set up each computer as appropriate for the type of connection (including installing drivers for the USB as needed). For more details see: http://broadband.motorola.com/consumers/products/SB4220/downloads/SB4220_userguide.pdf .
I hope this helps.
Nov 06, 2010 | Arris SURFboard SB4220 Modem
Broadband modem linked to computer thru usb.
Please check the the LAN card is working or not
you can check by typing IPCONFIG in command promp and after that type ping 127.0.0.1
If you are getting reply then the LAN card is working.
Check the ethernet cable after that
May 04, 2010 | Belkin (F5D7230-4) Router (587009)
EMule TCP Port 11522 not reachable
Does you norton program have a firewall included with the software? If so, your windows firewall was probably turned off automatically because having two firewalls running simultaniosly can cause a conflict between the two firewalls and therefore will not work correctly.If you have a firewall included with your norton software make sure it is turned on and leave your windows firewall off, other wise turn your windows firewall back on.
As far as your situation with the broadband modem, I have to ask: Is your Thomson hardware a broadband router (wireless/wired), or are you using an access point? (wireless/wired) If you are using a "router" there is no way to set it up to work with the modem the cable company provided you. However, if the Thomson modem hardware is an "access point" the only thing I can suggest is to follow these steps:
1) Pull the power cord out of the back of the modem that the cable company provided to you.
2) Next, plug in your Thomson router in to the ethernet port of the computer.
3) You are then going to configure that device. Start by going to the "network and Internet" section in your control panel. There should be a section in there where you can click that says "setup a new network connection" There should be an option to set up and "access point" and it will search for your hardware. If your hardware is found you will probablybe promped to input information about your router and once that's done it should set up successfully. If it isn't successful by some chance don't give up just yet! Go to step 4-
4) Shut down your computer.
5) next, switch the ethernet cable going from your Thomson hardware to the modem from the cable company.
6) You will then need a second ethernet cable to go from a second port of the Thompson hardware in to the ethernet port on your computer.
7) next, plug the power cord back in to the modem from the cable company and your Thompson hardware and start up your computer.
You should be able to get a wired internet connection if all goes well. If you have a wireless access point go ahead and set up a separate internet connection only this time choose "wireless" and choose your settings. I hope this helps. Feel free to contact me anytime if you have more questions. Happy Holidays!
Rachel
Dec 04, 2009 | Computers & Internet
I need help connecting a westell 7500 router/modem,i want to get a notebook on line. i didnt receive any intsructions.i need help connecting the westell 7500 to my pc and notebook thanking you.
Westell makes a line of broadband home networking products that enable residential customers and users in small businesses to access and share broadband services. These inexpensive DSL router/modems offer multi-users Internet LAN access for home or business applications. The Westell router/modems allow you to have the benefits of the "always on" high-speed broadband Internet connection without losing the ability to receive voice calls over the same phone line.
  1. Step 1 288254_thumb.jpg Connect one end of the Ethernet cable to the computer's Ethernet port. Connect the other end to the Ethernet port on the back of the Westell router.
  2. Step 2 Connect the barrel end of the router's power cord to the connector labeled "12 v" on the back of the router. Plug the other end of the power cord into a wall outlet.
  3. Step 3 Connect one end of the DSL phone cable to the DSL line jack on the back of the router. Connect the other end to the wall jack.
  4. Step 4 Wait for the Ready and the Link LEDs to glow steady green. The router is now ready to use.
Nov 15, 2009 | Westell Wirespeed VersaLink...
Ethernet cable 'splitter': Works on AT@T 'light' modem but not on cable modem. Are splitters speed sensitive
Splitters that work on telephone modems are not designed to work on cable modems. If you are trying to allow more than one computer to access the Internet, you need a broadband router.
You can find them on eBay and at stores for under $30. The primary difference between them is the number of "ports". A port is simply a place to plug in your PC. The more ports, the more PCs you can plug in.
Here's how you set a router up.
1. Plug a short Ethernet cable into the Ethernet "out" port on your cable modem.
2. Plug the other end into the "Uplink" or "WAN" port (will be labeled one or the other.
3. Plug an Ethernet cable into the LAN card on your PC and the other end into one of the open Ethernet ports on the router.
4. Reboot each PC.
You should be good to go!
Oct 25, 2009 | Linksys computers10: EtherFast Cable / DSL...
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Automatic installation failure
unless you were switching from DSL to cable Broadband, there usually wouldnt be much reason to rerun the software just because you got a new computer. when you ran the software the first time on the other computer, it was the router you were setting up, not the computer.
if the new computer is not getting internet when hooked to the router, try this.
1.turn off computer and unplug electricity from router and cable modem.
2. connect all ethernet cable to the right location. ethernet from modem to router goes in the non-numbered port, ethernet from your computer to router goes in numbered port.
3. plug in cable modem electricity first, wait for all its lights to come on like normal.(this part is important). the ethernet light on the modem (it might be labeled ethernet, link, pc link, or something similar) will not be lit, this is normal until you get to the next step
4. plug in the router electricity, give the router 2-3 minutes to get connected to the modem.
5. start up the computer, wait for everything to fully load and check internet again.
hope this helps.
Mar 21, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G 2.4Ghz Broadband Router Problem
You have to check if your computer can connect to the modem with an Ethernet cable. This will tell you if the ethernet port on the modem is working. if that does not work call your cable provider.
Next thing after you get the instructions above done.
Press the reset button on the back of the router> press it in for 30 seconds then let go and pull out the power. Connect the router up the way it should be before you reset by the way. check if you have internet if you do not follow hte directions at teh link below.
CABLE SETUP
If you need more info just message me
Aug 29, 2008 | Linksys Wireless-G Broadband Router
Intel D845GVSR Motherboard Logo
177 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
