Question about Toshiba Satellite A15-S157 Notebook
Toshiba satellite tablet
Whenever I minimize my programs, it no longer is available on my task bar. I have to hit alt tab to find it and move through them...i would like them available on my task bar again
Tried that, unfortunately it didn't work. my whole bottom taskbar is dominated by the tablet keyboard.
Posted on Oct 30, 2008
    Genius:
  • Toshiba Master
  • 1,250 Answers
You have to right click on the taskbar and select lock the taskbar
Posted on Oct 01, 2008
Toshiba satellite saying bootmsgr is missing
After you hit ctrl alt del. A menu should come up.Choose task manager.
Once open,go to running application. Highlight it and choose end task.
Oct 19, 2011 | Computers & Internet
Tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
on Nov 12, 2014 | Microsoft Windows XP Professional With...
Tip
Shortcuts tricks for Windows Vista(Keyboard shortcuts)
Following are some of keyboard shortcut tricks for Windows Vista and also for Windows XP:
  • Window key+B: Sets focus to first icon in the notification area. You can use arrow keys to move among the icons in the notification area or press Tab to move around on the task bar.
  • Window key+D: Show Desktop (without the Sidebar).
  • Window key+E: Windows Explorer (opens to Computer).
  • Window key+F: Find Files or Folders (aka Search).
  • Window key+M Minimize All windows (Sidebar not included).
  • Window key+Shift+M: Undo Minimize All Windows.
  • Window key+R: Open the Run dialog box.
  • Window key+Tab: 3-D Flip (flips you through your applications but with a cool graphic instead of the standard Alt+Tab). Requires the use of the Aero user interface.
  • Window key+Pause/Break: System Properties.
  • Window key+F1: Windows Help.
  • Window key+L: Locks workstation. If the user account has a password, it must be reentered to unlock the system again.
  • Window key+U: Ease of Access Settings.
  • Window key+ Spacebar: This shows the Sidebar (the Sidebar must be open, but minimized).
  • Ctrl+Window key+Tab: Brings up Flip-3D, but it will stay on the desktop so you can scroll up, down, left and right.
  • Window key+T: Allows you to tab between application buttons on the task bar.
  • Ctrl+Shift+Esc: Opens Task Manager more faster than alt+ctrl+del.
  • Alt+Tab: Windows Flip. Allows you to choose an open application to switch to by repeatedly pressing the Tab key.
  • Window key+5: opens the snipping tool.
Some User Logging Shortcuts:
  • Window key (and then) three right arrows and Enter To Shut down
  • Window key (and then) three right arrows and U To Shut down
  • Window key (and then) three right arrows and R To Restart
  • Window key (and then) three right arrows and W To Switch Users
  • Window key (and then) one right arrow and Enter To Sleep
on Jan 16, 2010 | Microsoft Windows Vista Ultimate Edition
Is there a preferred startup menu for my Toshiba Satellite L655-S5078?
Regarding a computer's start-up menu, it is optional. You can choose which start-up programs you want to run on your computer during start-up. To access its control, just follow the steps below.
  1. Click on Start.
  2. Type msconfig on the start search bar and hit enter.
  3. MSCONFIG window will come up. If you see a check box that says "Disable all Microsoft Programs", put a check on it.
  4. Click on the Start Up tab.
  5. Carefully uncheck all the programs you don't want to run upon start-up.
That's it. Running minimal programs on start-up can help speed up your computer's initial load process.
May 21, 2011 | Toshiba Satellite L655S5058 Notebook PC
Model is Satellite A135-S4727. Boots up in safe mode, but black screen when I try to do anything from there. I removed the battery and went to ac. Screen when booting works and I see the that it is...
when it goes to the black screen give it a few seconds after the mouse shows up. Ctrl+Alt+Del and select task manager, then select the process tab. click on explorer, then right click on it and select end process from the pop up menu. once it has disappeared go back to the first tab programs. click new task, type explorer and hit enter. see where it gets you from there. if that doesnt help please recover your computer per manufacture instructions.
Mar 20, 2011 | Toshiba Satellite A135-S4727 Notebook
Webcam on my toshiba netbook says its being used by another program
Is this when you try and run a program?
Try restarting your computer to free it up.
Mar 01, 2011 | Toshiba Satellite A205-S4617 Notebook
When I turn on my PC, all that appears is the ''Satellite'' logo and my mouse arrow. I brought up the task bar by pressing cntl-alt-delete and found only one task that would open....''Pinball''. All others...
If you can bring up the task manager , go under the processes tab and see if Explorer is running.
If it isnt go to File > New task and type in explorer and hit ok.
Apr 22, 2009 | Toshiba Satellite A105-S2051 Notebook
Window disappears then minimized
Press the Esc key. If that doesn't do it, try the Space bar, or Enter key. Last but not least, the Tab key MIGHT do the job.
Dec 25, 2008 | Toshiba Satellite A105 Notebook
Where is tab key & alt key does not work in dos programs
Tab key is located on the lefthand side of the keyboard just above the Capslock key and says TAB on it,It should also have two arrows,One facing left and one facing right.
Try the other Alt key located at the other end of the space bar
Oct 30, 2008 | Toshiba Satellite A15-S129 Notebook
Minimised
You can Alt+Tab to bring back up a minimized application, or use Task manager to switch to that application (right click on the task bar and select task manager to start it)
I hope this helped...
Feb 28, 2008 | Computers & Internet
Toshiba Satellite A15-S157 Notebook Logo
111 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
