Question about Home Plan Software Easy Mail
I have had easy mail in my computer since around 2005 I think, with all my addresses and everything in it, so when my computer crashed and died and I got a new one and asked the man to put all the stuff I needed into my new one, I didn't think to check if he had put the Easy Mail in, and now I find he didn't! Can you find my old one for me, or should I buy a new one? If it has to be a new one, can you supply it? It was the best address book and label printer and I am quite lost with out it. Margaret Winter.
    Top Expert:
  • Home Plan So... Master
  • 75,822 Answers
Never heard of this.
Posted on May 19, 2017
Forgot my sceen name and pasword carl davis lampasas tx
Computer experts usually have software that can bypass or reset your password on your computer. Even Best Buy's Geek Squad could do it. It's usually simple and fairly cheap as long as you didn't use an encryption scheme.
If it's websites you're trying to get into, usually you can put in your email address and receive an email to change your password when you don't remember it.
If you've changed e-mail and never updated it on the website, you still might have a chance, your old e-mail could be available a year or more after you quit using it.
Jul 26, 2016 | Computers & Internet
My 2005 trailblazer cuts off when in gear when the defrost/ac is turned on. Just had a brand new transmission put in the day before this started. Would that have ANYTHING to do with this happening? What...
VERY easy fix, and a VERY common problem. When they put the new tranny in they had to unhook the battery. When the battery is hooked back up, computer thinks everything is clean and adjusted well. Problem is, your throttle body is dirty, so the computer isn't adjusting for fuel correctly because it thinks it's clean. Rip that throttle body off with the battery disconnected, it's only 4 bolts and disconnect the wires. Clean with Seafoam or throttle body/sensor safe cleaner using towel or toothbrush. Do NOT use wire brush, will mar the aluminum. After everything is clean, put back together and hook the battery back up. With all HVAC OFF, drive around for 15 minutes or so, so the computer can relearn all correct settings. Problem solved, should clean the TB on a regular basis. By the way YES you can reuse the hard plastic gasket on the TB. $7 fix if you do it yourself. Good luck!
Feb 23, 2015 | 2005 Chevrolet TrailBlazer
I cant log into facebook account
I'm having the same problem, maybe it's on the facebook end thats where the problem lies
, because I was on it yesterday in the AM but nothing since
Nov 23, 2013 | Facebook Social Network
My computer problem is 0x3bc3 just crashed
Saw a solution in the web and it helps. Try the following step;
"System process at address 0xE4783995 have just crashed, please follow these steps to deactivate it from your system." is a fake warning and the only visible part of the infection which is defined as a Trojan/Ransomware. It's a piece of malware that blocks pretty much everything on your computer and demands payment in exchange for the identification key. In order to remove the "System process at address 0xE4783995 have just crashed"
STEP
Enter this code: 754-896-324-589-742 to unlock your computer.
HOW TO UNINSTALL IT
To remove all System process at address 0xE4783995 have just crashed files, you must kill all System process at address 0xE4783995 have just crashed processes that are running in your computer's memory. To kill System process at address 0xE4783995 have just crashed processes, press CTRL+ALT+DELETE to open the Windows Task Manager. Click on the "Processes" tab, search for System process at address 0xE4783995 have just crashed, then right-click it and select "End Process" key.
You'll also need to remove System process at address 0xE4783995 have just crashed registry keys. To remove System process at address 0xE4783995 have just crashed registry keys, click on the Windows "Start" button and select "Run" to open Windows Registry Editor. A window will popup. Type "regedit" into the box, and click "OK". Search for the registry key "HKEY_LOCAL_MACHINE\Software\System process at address 0xE4783995 have just crashed." Right-click it and select "Delete."
Finally, you'll need to manually delete other files to clean your PC of System process at address 0xE4783995 have just crashed. These System process at address 0xE4783995 have just crashed can be in the form of EXE, DLL, LSP, TOOLBAR, BROWSER HIJACK, and/or BROWSER PLUGIN. For example, System process at address 0xE4783995 have just crashed might create a file like
%PROGRAM_FILES%\System process at address 0xE4783995 have just crashed\System process at address 0xE4783995 have just crashed.exe. Locate and remove these files.
Jul 04, 2011 | Computers & Internet
Hi i have labtop acer emachine e 510 when i wanna log in this message appear system process at address 0x3bc3 have just crashed please follow these steps to deactivate it from your system * i cant...
IT is a fake warning and the only visible part of the infection which is defined as a Trojan/Ransomware. It's a piece of malware that blocks pretty much everything on your computer and demands payment in exchange for the identification key. In order to remove the "System process at address 0x3bc3 have just crashed"
STEP
HOW TO UNINSTALL IT
3bc3 have just crashed files, you must kill all System process at address 0xE4783995 have just crashed processes that are running in your computer's memory. To kill System process at address 0x3bc3 have just crashed processes, press CTRL+ALT+DELETE to open the Windows Task Manager. Click on the "Processes" tab, search for System process at address 0xE4783995 have just crashed, then right-click it and select "End Process" key.
3bc3 have just crashed registry keys. To remove System process at address 0x3bc3 have just crashed registry keys, click on the Windows "Start" button and select "Run" to open Windows Registry Editor. A window will popup. Type "regedit" into the box, and click "OK". Search for the registry key "HKEY_LOCAL_MACHINE\Software\System process at address 0x3bc3 have just crashed." Right-click it and select "Delete."
3bc3 have just crashed. These System process at address 0x3bc3 have just crashed can be in the form of EXE, DLL, LSP, TOOLBAR, BROWSER HIJACK, and/or BROWSER PLUGIN. For example, System process at address 0x3bc3 have just crashed might create a file like
3bc3 have just crashed\System process at address 0x3bc3have just crashed.exe. Locate and remove these files.
Jun 29, 2011 | Computers & Internet
Samsung scx 4300 at home. Can I?
yes you can refill in your home its very easy process after refill you need to reset your printer
send me your e-mail address i can send to you detailed information how to reset toner counters with software
MUSTAFA BULENT KILIMCI
YUNUS COMPUTER CEO
COMPUTER EXPERT
e-mail & msn : address mbkilimci@yunuscomputer.com
Jan 07, 2010 | Samsung SCX-4300 Monochrome Laser...
Help
It would appear that someone has sent you mail and spoofed your return address. A very easy thing to do.
This is frequently used by spammers to make your computer think it's a legitimate piece of mail.
I think hotmail can be set up to call this type of thing spam. You can always set up a filter that says to put all mail with your return address into the spam folder and then you can check to see if it's legitimate.
Sep 24, 2009 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
Top Home Plan Software Computers & Internet Experts
David Payne
David Payne
Are you a Home Plan Software Computer and Internet Expert? Answer questions, earn points and help others
