Question about Brother ML-100 Typewriter
Almost Fixed. Stricker works, but sticking
Upstateos, I see why you are label Guru. Yep, keyboard has switch, acting as reference point for carriage. Put all back together, and typed paragraph. But then stricker went forward, and stayed, actually pushing tab forward in daisy wheel (stopped daisy from spinning, also). Happens primarily when I hit the "correct" key. But at first, the correct key worked, whited out last letter.
When I openned everything, there is a circular adjustment on right side that I had to loosen to release tab from a track on the end of the cam assembly that sends stricker forward. And there was a torsion spring. This let me lift up the correction housing, the housing the ink sits into. I took notice of where this adjustment was at, and also the spring location. And I've put it back, like I thought it should be. And, at first, all was well. But then the striker stayed forward when I hit the correction key. (Correction worked a few times before it stuck.)
Now, I've relocated this side circular adjustment in all possible settings. And still the same thing happens. It will type fine, till I hit the correction key. Is there a parts breakdown, and/or explination of this adjustment?
Thanks for helping. You are good.
  • eddie27970 Aug 14, 2008
    You nailed on the head! Thanks. Took little white side adjuster out, turned on and let it reference and reset, put white side piece back in and set it to the adjustment I had seen when first removing it, and now, the striker works fine, even in erase.
    But...just when you thought it was safe to go back in the water, the daisy wheel is messed up. The other day, when the striker was stuck forward, I put it up. Apparently, this deformed the one tab of the daisy wheel...being pushed forward and to the side, somewhat, Looking for new daisy wheel now.
    But all else is now fixed, thanks to you. Of course, the secretaries in the front office think I'm their hero (not you.) Ha-Ha. Sorry about that. :)
  • 329 Answers
This part yu take off, the pin goes into a slot that goes around inside a cam. If you have that pin not in the slot you will get this lock up. Try taking the part you mentioned out or remove wht is called the ribbon plate, which is the part where the ribbon sets on, then turn the machine on or wind the printer motor by hand to home out or bring the printing unit to the home or start position, turn off and very carefully install the parts you tokk off making sure the pin in the ribbon lift (The small part yout ook off on the right side of the printer) is in the correct cam track or small track or canal. Once installed you can rotate the motor by hand an see if it moves freely. GOOD LUCK
Posted on Aug 13, 2008
Hi, I have a Dell Latitude E6400 laptop running on windows XP service pack 2. Recently, my mouse is acting weird jumping to the upper right or lower left corners of the screen and freezing there. I am able...
This problem is common in all laptops that have a pointing stick (eraser tip like) in the keyboard between G H and B buttons. It's a registry problem that cannot be fixed easily. The most economic and time effective way t solve it is to format your hard disk and reinstall your operating system.
Make sure to update your operating system before downloading any other programs or application and even before uploading your backed up files.
If this does not work for you, the problem will definitaly be a hardware issue caused by the pointing stick. Then the keyboard or the motherboard of your laptop should be replaced (I hpe your laptop is still on waranty....)
May 10, 2011 | Dell Latitude E6400 Latitude E6500...
My whirlpool top load washer won't drain and spin
This is likely to be a problem with the lid switch.the lid switch is activated by the lid stricker when you lower the lid.these machines will normally fill & wash without needing the lid closed but when it gets to spinning & draining the lid must be closed,so the machine is acting as though the lid is open.the lid has probably been dropped or slammed shut & this can break the lid switch from where it mounts with 2 phillips head screws.
May 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Prints only part of label
Fixed problem. Labels were too thin so LED was still being detected to stop progress of labels. Fixed by sticking some backing paper over the sensor and seems to be working fine.
Jun 12, 2009 | Zebra Eltron Orion LP2443 Thermal Printer
Adding ram, but computer freaks out.
there is a jummper on the mother board you need to take off.
Jan 05, 2009 | E-Machines eMachines Desktop PC
Gas range with stricker burners and oven burner
Most likely the oven will not work because the striker is not coming on. I am not very familiar with this stove but most thermador gas oven uses a electronic igniter. the switch controls both the igniter(striker) and safety solenoid so if neither the striker or solenoid is not powered up the switch may be the problem
Nov 07, 2008 | Thermador SGS36GS Gas Cooktop
The correctional tape isn't popping up to white-out the errors. Instead the actual ink is typing where it should be correcting making the letters bold. I tried tightening the correctional ribbon and the...
Hello. I had a similar problem, and Upstatoes helped me. Mine started with striker stuck forward, and then went to working for a few days, but sticking forward again And it was caused by the spring not being in the right place. But the correction tape housing is pushed up and pulled down by the white, adjustable piece on the right side, that has the screw holding it into the adjustment place. If you take off the ink ribbon, push the carriage to middle, and turn on the typewriter, there will be a switch at the top left of the keyboard, on the underside, you will need to flick with your finger, one time, as the carriage moves to the left. This is the reference switch, and you will be tricking the typewriter into thinking it is now in the left side start position. After this, you can see the white adjuster piece on the right side of the carriage, and, as you type a letter, also see if it is holding down the correction tape housing. Then when you hit the erase key, see if the cam on the inside (looking through the small holes in the correction tape housing) turns and pushes up this housing? It may be the tab in the white adjuster is not inside the grove of this cam. Either way, at that point, you may be able to see if something else is not as it should be? My problem was the long side of the spring was not underneth the white adjuster. (I had been putting it under the housing, and it was not helping ot push everything up like it should be.) Aparently this cam with the white adjuster tab in the groove holds everything down, easily, as you type, but has to have the spring help to push up when you use the earse key.
Aug 15, 2008 | Brother ML-100 Typewriter
Striker Sticking When Erasing. Brother ML100 Typewriter
Sounds like the gears you cleaned may be dry and sticking, spray a little WD40. or that gear on the right side is still out of time. I think there is a spring clutch in the gear train which may be bad. One secret to repairs is to perform the same actions that you want the typewriter to do by hand and watch closely. You may see something not movving, or moving slow that under power you won't see.
Aug 14, 2008 | Brother ML-100 Typewriter
Striker Not Working. New Problem, now.
One very important thing with Brothers typewriter, If the keyboard is not locked in place under the catches, it will not complete the home cycle. In other words when the carriage returns to the left it will cycle and then beep usually continually. The reason the carriage stop time switch is attaced to the keyboard not the side frame. You might look at that....Could be other problems too. keep in touch
Aug 05, 2008 | Brother ML-100 Typewriter
Smith-corona deville
Look for a used board or used typewriter on E bay or through office products dealers, Let me know model and I may have
Jun 10, 2008 | Office Equipment & Supplies
Switched Keyboard symbols
Go to control panel on start menu.You may have to click Classic View. Click Regional and Language options. Click middle tab at the top called Languages. Click the Details button. Click Add and select the English UK option from the drop down list. Apply and Ok.
Mar 05, 2008 | Computers & Internet
Brother ML-100 Typewriter Logo
James Cagle
James Cagle
Jim Keysor
