Question about Metrologic Instruments Metrologic Barcode Scanner Voyager BlueTooth Replacement Li-ion Rechargeable Battery
MY METROLOGIC BAR CODE
HELLO..!! I HAVE A QUESTIONS.. my reader of bar code metrologic MS-7625 scans but he does not register anything to me in the screen. IT CAN BE DRIVER?
What Is The Communication Method You used, usb or Kbw,
Posted on Sep 25, 2008
SOURCE:
Metrologic ms9520 not scanning UPC's
Hello.
The issue is likely due to the programming (or the lack of) of the scan gun. It is entirely possible that the UPC bar code is not configured in your gun as a valid bar code.
You can remedy this by programming the scan gun to recognize the UPC bar code (and any other bar codes you may need to scan). Use the link below to download the programming guides for this scan gun.
http://www.honeywellaidc.com/en-US/Pages/Product.aspx?category=hand-held-barcode-scanner&cat=HSM&pid=9520/40
Hope this helps!
Dec 01, 2011 | Metrologic Instruments Voyager MS9520...
We can not get the scanner to reset to the factory defaults.
I am not sure if you try this yet,
If you scan the bar code located on page 14 from the manual (link below) it should reset the scanner back to factory default
http://www.barcode-uk.com/images/downloads/Metrologic%20MS1690%20Scanner%20CernInst.pdf
I hope this helps and best of luck!!
RM
Mar 10, 2011 | Metrologic Instruments Metrologic MS1690...
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
I need to program a <tab>suffix character
Just go to page 8-6 and scan the "Enable Tab Suffix" Barcode that is 5th down from the top of the page. It took me awhile to figure it out too. Hope this helps someone since the question is a year old...
Jul 09, 2009 | Metrologic Instruments MS9535 VoyagerBT...
METROLOGIC BARCODE READER WAS WORKING NOW NOT WORKING
USB CABLE PLUG IS DAMAGED. HOW DO I REPLACE IT OR FIX IT. ITS VITAL TO OUR BAR CODES. CHARLES FRAZIER TEXAS FARM BUREAU 254-751-2580 THANKS
Apr 18, 2009 | Microsoft Metrologic MS3780 Fusion Barcode...
Hooked scanner up to new computer. Reads bar code
It sounds like you are connecting to a serial port and you are trying to scan into a program that needs keyboard data. Download the "Softwedge" program from the Metrologic website.
Mar 27, 2009 | Metrologic Instruments 9520 Voyager
Ms9520
try to reset a bar code ,from the manual
Jan 24, 2008 | Metrologic Instruments METROLOGIC VOYAGER...
Metrologic 9520 help...Please
Is it 13 digit barcodes you are trying to scan?
Also, does the cable go straight into your till (straight cable) or is it connected to you keyboard via a wedge?
Jan 19, 2008 | Metrologic Instruments 9520 Voyager
Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
Open Questions:
See all Metrologic Instruments Metrologic Barcode Scanner Questions
490 people viewed this question
Top Metrologic Instruments Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you a Metrologic Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
