Question about Kitchen Ranges
My pitco violator is giving me a heat failure wbarning ...
  • 8,220 Answers
I was looking through this Turbo fry service manual
just now and looks like these units use something similar to a Kanthal spark/sensor.
The spark/sensor does 2 jobs. Lights the fire AND monitors the flame. If grease and junk gets on the spark sensor it won't confirm ignition and declare the failure. So clean up that thing real good or replace it and see if the problem is solved. Get your parts and service manual for your model here
Posted on Apr 07, 2011
My pitco fryer SFSG18 will not light it has spark but does not seem to be getting gas when trying to light
Have you tried inspecting/replacing the thermocouple? This is the thing you heat when initially lighting the pilot.
You may also have a stuck pressure valve, but that is unusual.
Apr 02, 2016 | Pitco Frialator SG18S Deep Fryer
Pitco fryer pilot light wont stay lite
The thermocouple is bad or the pilot light is not adjusted to heat the thermocouple to the point where the safety shut off stays on.
Jul 09, 2014 | Pitco Frialator 35CS Deep Fryer
My Pitco fryer heats up and operate normally at 250 degrees when I set to 300 degrees, it heats up and when it reached 300 degrees, it shuts down bunner as well as the pilot light
CHECK THE SMALL SOLINOID THAT FEED THE PILOT IF THAT OPENES EVERYTIME THE FRYER STARTES THERES YOUR PROBLEM REPLACE IT AND ALL SHOULD BE WELL
Feb 09, 2014 | Pitco Frialator Kitchen Appliances -...
Would Pitco 35C+ still heat if bulb/capillary of control thermostat breaks?
Hi there.
The unit will not fire up if the capillary of thermostat is broken or punctured because the thermostat's mechanical contact will remain open.
Regards.
Jul 08, 2011 | Pitco Frialator 35C Deep Fryer
Hi I have a pitco sg14 fryolator. At the time of firing off main burner there is a false ignition at start of heating cycle of oil in tank and there is a woosh sound that shakes front door so basically the...
for the latest design of pitco frialator, the manufacturer added what they called the self-cleaning burner system.during start-up, ignition is delayed so that dust accumulating in the burner face will be removed once the gas build up on burner chamber ignites, it creates a weak explosion like sound.the next time you hear that during start up, the unit is cleaning its own burner, no need to worry.
Mar 28, 2011 | Pitco Frialator SG14 Deep Fryer
Pitco Fryer is displaying CHECK SUM FAILURE - in almost 10 years, I have never seen this display - what is it????
Check sum failure is an error on the configuration of the computer board. You have to reset the computer board to factory setting to get rid of this error (if check sum failure appears every now and then on the display). Make sure that you have the list of your cooking parameters before you reset the board to factory setting. Any settings made prior to a factory reset will be lost. Details on how to reset the board to factory setting can be downloaded at pitco website on www.middleby.com.
Feb 20, 2011 | Pitco Frialator SG18S Deep Fryer
I have a used sg-14 pitco that i want to use outside for my family reunionsdo i have to use a large tank oflp or can i use a 30-lb tank when i light the pilot it will not stay lit when i release the button...
You can check the voltage generated by thermopile using a voltmeter. Set the voltmeter on milli-volt setting then heat up the thermopile. When properly heated, it can generate 500 to 750 milli-volts.
May 20, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco fryer leaks when oil is hot but can't find where is leaking from
Hi, I have the same issue, did you manage to locate the leak? I think mines comes from the heat tubes.
Dec 17, 2009 | Pitco Frialator SG18S Deep Fryer
Hi need sper part for pitco fryer flame failure valve model no 14
It sounds like you are not recieving a heat feedback signal. It may be as simple as cleaning your flame sensor, using a emery cloth/ scotchbright. Be sure that all gas is turned to the on positions. Also that any safty high limits are closed / reset.
Scoota
Dec 12, 2008 | Pitco Frialator SG14 Deep Fryer
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
