Question about Yamaha POCKETRAK 2G Pocket Stereo Recorder
My recorder functioned just fine for about a year and a half. Now all of the sudden it only records and plays back loud static. I've never dropped it or anything. Does anybody have any idea what could be casing this? I just hope the mic isn't broken irreparably.
  • thedre Sep 07, 2012
    I don't think it's the mic. If you notice, however, if you have it set to show levels just before recording, the Yamaha is getting static noises entering the unit without the mic doing it. It's some kind of crosstalk inside the system.
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: problem with analog recording on Yamaha CDR D651
Your assessment that it duplicates CD's internally fits with an analog-only failure mode. Let's make sure the signal is getting past your RCA jacks on the deck...
Put the deck in a Rec/Standby mode and make sure an analog source registers adequate volume on the meters. If it's good there and doesn't change with cable swapping between the input channels, you're right, the problem is internal. Maybe the volume potentiometer itself has developed a dead spot. Manually rotate it throughout its range many times to wipe it clean.
If you have an external optical digital source use it to check the meters in digital recording mode to be sure they're about even. The same knob affects analog and digital levels.
If you have the deck connected via the traditional Tape Monitor circuit in a receiver you should be able to tell by ear if the one channel is dead or too low. This puts all of the recording circuitry including the volume knob in line with your receiver.
Posted on May 17, 2009
Sony stacking system LBTd505, the sound from the record deck suddenly went very faint. The cd and radio sections are fine. I have tried a new stylus, but no difference. Any ideas?
You have two options. First a faulty cartridge. Or a faulty pre-amp in the main amp.
You can find out if the cartridge (and amp) are playing up. By removing the connectors on the cartridge.
Then with the volume turned up to about half, with your finger, touch each one of the wires one at a time. It will not harm you at all. But you should hear a loud buzz on one wire on the right and a loud buzz on the left on another wire.
The two other wires will either produce a crackle, or a tiny buzz, or nothing at all.
If you do hear a loud buzz on two wires. The cartridge is faulty and needs replacing.
If you hear a slight buzz on them or weak sound. There is either a bad connection between the deck and amp. Or the pre-amp inside the deck which is only used by the record deck so will not effect any other function, is faulty.
You can remove the record deck connections to the amp and again with the amp on half full, touch the inputs with your finger. If you are not hearing a loud hum or buzz, the pre-amp is faulty. If you do the connectors are faulty.
Jun 11, 2016 | Sony Audio Players & Recorders
I have loud static in my Zoom h4n
There's dirt in there. If you know how to spray contact cleaner in the appropriate place, do so. If not, take it to a competent repair person.
Mar 04, 2014 | Audio Players & Recorders
Zi8 records static not voice
Sounds like it could be one of two things. Either the mic itself went out or the communication between the mic and board disconnected somehow. Has it been dropped or jiggled around in a bag? You could take it to a camera repair shop but it may be cheaper just to get a new one altogether. If you're under a year of owning it you could also contact the manufacturer.
Dec 04, 2013 | Kodak Zi8 Digital Camera
I have a JVC turntable (AL-A155TN/AL-A155TNX). I haven't used it in about ten years. I hooked it up today. I played four records on it. Two were fine. The other two, however, started off fine
The only thing that might cause something like that is a build up of static. You can buy anti-static products for records and turntables. I tend to use an anti-static spray which also cleans the records.
Jan 14, 2013 | JVC Audio Players & Recorders
My Canon PowerShot SD300 was recording sound perfectly a few days ago. Now whenever I record a video and play it back there is no sound except for static. I have resetted the settings to factory defaults...
When you play the video back and get no sound are you doing this on your camera or on the computer? I have the same camera, and noticed that when I playback something I've recorded I don't have sound either, mind you I don't have static either. But once I've uploaded the video onto my pc the sound is there.
Jul 29, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
Camera suddenly will not record
This looks like a relay or micro switch has gone, camera needs looking at.
Jun 20, 2010 | Panasonic NV-DS65 Mini DV Digital...
Loud noise when trying to set to record or to play the noise is like loud static and I have to turn off both the TV and the DVD player to get it to stop the noise  I suspect it is the control
When you hear the static, turn power off and then back on again and it will go away. Some players have been know to do that. It is a problem with the programming. Just turn power off and right back on again and it should be fine.
Aug 06, 2009 | Televison & Video
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
Just bought it but threw the box away because it worked right the first time!
Caution - some manufacturers recommend a specific type of CD for recording, otherwise the unit may not record properly. Was the CD a CD-R? CD-RW? 74 minute? 80 minute? See if there are any specific requirements first.
Mar 13, 2008 | Audio Players & Recorders
Playback problems started suddenly
I had the same problem. I fixed it by gently dropping the camcorder on the carpeted floor. I know it sounds silly, but it really works. I've had to do it twice, and it worked both times. I hope it works for you.
Jan 08, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Yamaha POCKETRAK 2G Pocket Stereo Recorder Logo
32 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
