Cycle stops - F error code
I own a White Kenmore Elite Oasis™ 4.6 cu. ft. Canyon Capacity™ Washer, Sears item# 02627072000 Mfr. model# 27072. The cycle keeps stopping in the middle, giving me an F error code, not follwed by a number. This washer is less than a year old.
  • 1 more comment
  • kastle Oct 22, 2008
    I'm having the very same problem. It's very frustrating because I have a family of 8 and cannot do without a washer. Someone please offer some advice! The machine starts going but in just a few minutes, stops and starts flashing an "F". No numbers with it. Does anyone know what this means because I do not have my owners guide anymore.
  • Anonymous Nov 24, 2008
    F error code need a solution.
  • Anonymous May 08, 2009
    I'm experiencing the same problem w/ my washer. It starts off fine but within a few minutes it locks up and starts beeping. It also flashes the letter "F" alternating w/ the time remaining for the wash cycle. There are no numbers, just an "F", which I am starting to think is very appropriate for how I feel when this happens. And of course I can't find the manual. Any help is appreciated.
I am having the same problem with the "F" flashing and a beep but no numbers. The manual only says to hit the stop button then the start again. It doesn't give you a problem. It then says if this does not work to call a repair man. Mine is only two years old and we loved. I have never had any problem with it but every review I have read says differently and they seem to happen around the two year mark. It seems they have a malfunction timer that goes off at the two year mark. If you find a solution please post again.
Posted on Oct 26, 2008
SOURCE:
My washer will not spin and oL keeps coming up on it
My guess would be that oL stands for "overloaded" and that it will not run becuase of a weight sensor that says there are too many clothes in the load. You might try removing some of the clothes to see if it will spin as expected. if not, maybe the sensor responsible for reporting this error is registering an overload situation even when there isn't one.
Dec 15, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
Kenmore Elite Oasis washer does not lock
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 22, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
DU code for kennmore elite washer
I have the same problem. I replaced the lock latch and the code still comes up and note I I'm back to square one. Ugh I wish there was a way to disable the dash and reset it.
Sep 07, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
Kenmore Oasis HE model 110.27086604. I get the UL code on every wash. Never finishes cycle. Load is not too large, will do this with 2 shirts. If this is a suspension problem can I fix it?
Yes you will have to replace all four balancers (four corners). Same thing happened to us. We have five kids also and you can only imagine how much fun that was to do just two shirts or pants at a time. Ours was still under warranty so we had Sears fix it. Took quite a bit of time, but it is fixed now.
Aug 09, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore Oasis top loader giving us continual LF error code... how to fix?
long fill error code. might wanna clean ur screens. take the hoses off ur washer and clean the screens
Jan 31, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
LOUD RATTLING NOISES ON SPIN CYCLE (SOUNDS LIKE MONEY OR MARBLES IN MACHINE)
you'll need to investigate further. It may even mean bringing in a professional to be sure the vibration damper rods are ok - to prevent future and costlier problems.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
110.27082602 kenmore oasis elite
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Aug 28, 2008 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Washing Machines Logo
322 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
