Question about Garden
Craftsman 18.5 42'' rider dosent always engage the mower when lever is put in the on position, it takes several trys to get it to work or sometimes if you leave the lever in the on position and put the mower in gear and pop the clutch it will engage. any ideas why this is?
    Brigadier General:
  • 3,911 Answers
Assuming it is a lever that inserts a tensioner pulley into the deck drive belt loop: replace the pulley AND the spring which keeps the tension on. also replace the deck drive belt. use your cell phone camera and take lots of pictures before you take it apart so you are not one of those guys asking for instructions as to how to route the belt when you are putting it back together. the parts can be obtained at lawn mower/small engine repair shops which can be found in the yellow pages and on line.
Posted on Apr 07, 2011
Testimonial: "I will try this and see if it takes care of the problem. Thanks for the tip"
Will run but doesn't move
If it doesn't move at all; I would check the drive belt first, then the belt idler pulleys. Just make sure that no one has put the hydro units in bypass mode so they could move the mower without the engine running without your knowledge..
Feb 28, 2014 | Toro Zero Turn Rider 74366 Lawn Mower...
Craftsman riding mower wont start without having to pull up and down on the blade engage lever
Hi, there is a safety switch on the deck engagement that is faulty or needing adjustment, regards Phil.
Jul 10, 2012 | Craftsman Garden
I got craftsman lt 1000 runs great except when you put in gear or start blades can anyone tell me what they think the problem is
you didnt state on what it does when you try to engage the blades . im assuming that it trys to die . or least boggs out the motor .. also you didn't mention if this has the electric pto clutch or not .. if it has the pto clutch then id say that it has a relay missing or bad . also check the safety switches and make sure they are all working . most riders have one on the seat anymore and if its not working right then it causes a ground and trys to kill the engine . i know this isnt the proper thing to do but you may try to just unplug this one and see if that helps ...
Nov 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 2 year old Craftsman lawn tractor will no longer go in forward or reverse. It has the hydra static gear shift. All the belts look intact. Mower blades will engage. It is a 24 horsepower. Any...
There is a lever in the rear of the rider that allows you to disengage the transmission. It is intended to make the rider easy to push around. Make sure that hasn't gotten activated. The lever is usually located just above and to the right of the hitch plate (where a trailer would attatch). Sometimes it is located under the seat near the seat hinge. Hope this helps.
Good luck.
Sep 02, 2010 | Craftsman Professional 24 hp 42" Yard...
I've got a 2004 18.5hp rider model#917.273811 with the gas tank under seat. The thing is gravity feed but the way the fuel line is routed seems wrong from the factory. Not enough drop for a good siphon for...
Are you certain there is no fuel pump? Is this a briggs 18.5 engine?
On a related topic ... if you are a USA citizen ... there is a class action you should know about ... check out https://lawnmowerclass.com/
May 02, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Apr 25, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman zts 7500 will not run with levers engaged
Cody,
Yes, I am sitting when I do engage the blades on my craftsman zts 7500. All you do is pull/push the engaged button to your left well you are seated.
Apr 05, 2009 | Craftsman Garden
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
