Question about Poulan Garden
I cannot start my 1950 Wood Shark chain saw. I cleaned the carb & installed a new carb. kit New gas lines, bulb and a new spark plug. I have compression and Put Gas in the cylinder. It acted the same as before I did the above work. THANKS b.r.
    Guru:
  • 479 Answers
Problems with engines not starting usually come down to either an electrical problem and no spark at the plug, or lack of fuel.
Remove the spark plug and place the body of the plug against the engine.Check there is a spark when the engine is cranked. If no spark check there isnt a problem with the cut off switch.
The fuel lines may have become airlocked.This can happen if the tank is run dry. If the saw has a primer bulb, alternatively press it several times and then try to pull start the engine with choke on. Repeat this several times. The primer bulb should feel spongy and fill with fuel.
If you're up to it, you can dismantle the carburettor and clean any dirt from valves.The carburettors on chainsaws, hedge cutters etc are very fiddly with delicate diaphragms, valves and springs so you have to be careful to avoid damage or loosing parts.
Ensure air filter is clean. Foam elements can be washed with hot water and detergent, squeezed dry in a cloth and re-oiled with a teaspoon of engine oil spread through the foam. Paper elements can be cleaned with compressed air blown from the inside of the filter but ideally should be replaced.
Check fuel lines aren't kinked or blocked restricting fuel flow.
Ensure fuel filter isn't dirty. This is probably located at the end of the fuel line in the tank.
Check the throttle cable is actuating the throttle plate in the carburettor.
Check whether there is a vent on the tank or on fuel cap. There is usually a valve on this to allow air into tank to replace fuel as it leaves for the carburettor. Ensure this isn't blocked.
Hope this helps !
Posted on Apr 07, 2011
Saw would not start so I bought a new carb and it still won't start. Fresh gas, new plug, etc. How do I determine if I am getting spark to the plug and is it difficult to check the magneto or device that...
I would suggest finding an inline checker so you can visualize the spark without getting shocked for damaging the plug boot.
If your carb is working then when you take out your spark plug it should be covered with fuel. This could be a sign of no spark or it might be a sign of a dirty air filter causing an extreme rich condition. Try starting the saw with a clean plug and no air filter in place to rule this out. If it is dry you either have a fuel line issue or a blocked exhaust. Chain saws have spark arresting screens on them that can load up with unburnt fuel and oil *(from a bad carb or blocked air filter) be safe and good luck!
Mar 07, 2015 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
My Husky Chain 18 in saw wont start after replacing fuel line
I have seen the current gas eat away and melt fuel lines. I would bet there is some gunk in the carb which is why you are not seeing fuel on the plug. You will need to remove, disassemble, and clean the carb. If you haven't done it already make sure you replace the fuel filter too.
May 19, 2012 | Husqvarna Garden
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Need diagram of fuel lines from tank to primer bulb and carburator on a Poland chainsaw model 1950 wood shark
There are 7 different types of the 1950 model (types 1 - 7) and it came with one of these 2 carbs Walbro or Zama. The carbs are different as are the fuel line connections for each one.
Although this video is for the promer bulb you can see the routing of the fuel lines.
http://www.ereplacementparts.com/article/4262/How_to_Replace_a_Primer_Bulb.html
You will have one line from the fuel tank connecting to primer bulb the 2nd line going to the carb. If you connect it backward it does not pump fuel into the carb.
Kelly
(FYI Types 1 - 5 all have the same fuel line routing.)
Apr 12, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Nov 07, 2009 | Garden
Saw starts, then stalls when you increase the throttle. Spark plug looks fairly clear. Ay ideas on where to look next?
Yes, you will need to disassemble carburetor and clean with carb. cleaner. If you need tips on how best to do this, just let me know. Or you may need a new carb. kit.
Jim
Jun 01, 2009 | McCulloch Garden
Have a Poulan Gas Powered Chain Saw, I haven't started in 10 yrs.
check that plug is getting spark (remove plug, w/ cap attached hold tip of plug on cooling fin. pull starter rope, should see spark). if not receiving gas check filter in tank, if ok procede to carb possibly add a bit of starter fluid.
Mar 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
How do I install fuel lines on a poulan chain saw model 1950?From carburator to primer,from primer to fuel tank,two connections on each.
The smaller line comes from the fuel filter in the tank to the nipple on the side of the carb with the cover w/ 1large screw in the center, the other small line goes from the other nipple on the carb to the primer bulb, the larger line goes from the other nipple on the primer bulb back to the tank, and only gets pushed in about 1/2-3/4" into the tank. Hope this helps.
Feb 26, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan Wild Thing and Wood Shark Saws try to run, but stall down.
They could be sucking gas from the base gasket, head gasket or the bearings. Also, Check your flywheel very wheel and your armuter, if either are rusty then they need some sand paper to help create spark. There are rebuild kits and they are cheap. I always tell my customers to fix there older machines cause the new ones are **** and they leak everywhere and if anything brakes they are REALLY expensive to repair. You can get a rebuild kit whole machine for about 65 dollars
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
149 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
