Question about Sun Fire X4200 Server
I have a sun fire x4200 in front top fan and rear ps is orange
How to remove the bottom seat cushion in the rear of a Pontiac Sun fire
The front just slides over hooks in the front push down on seat and slide it
Jan 07, 2015 | 2003 Pontiac Sunfire
Won't boot
YOU HAVE A ELECTRICAL PROBLEM.OF YOUR DESCRIBTION YOU HAVE NOT ENOUGH POWER.TRY WITH A OTHER PSU.
Jul 10, 2013 | Computers & Internet
How to replace radiator 96 Toyota land cruiser
- Remove battery and tray (12mm bolts x 8, 10mm battery and ground. maybe 13mm for tray if some previous guy got confused).
- Remove fan from thermo (4x12mm) and shroud from radiator (2x12mm).
- Remove top small hose with pliers
- Remove bottom large hose with pliers
- Remove top large hose with pliers
- Remove two trans line hoses, and snake them up high so they don't leak anymore fluid
- Remove lower bolts near frame (13mm gear wrench) on DS ONLY
- Remove top side bolts from DS ONLY radiator frame (2 x 13mm).
- Remove PS center bushing horizontal bolt thru the front of the grill (12mm - 8in extension with wobbly and 12mm socket while vice grip the bolt on the engine side)
- Remove 12mm long vertical bolt from PS only (you are going to leave the DS frame in the truck and pull the PS frame out with the rad). Move the PS frame toward the rear of the truck, and remove/install.
Engine Chip
Nov 16, 2012 | Cars & Trucks
My Dell inspiron 518 will not turn on when power button is pressed. Green LED on back of power supply lights and orange LED on motherboard turn on. No fan operation on anything. Thinking it is the switch...
Green LED on PS means it's getting AC power. Orange light on motherboard means it's receiving power from PS but it may not be the correct voltage. The power supply isreceiving power from the source but is unable to properly distribute it to thecomponents. This can be caused by a defective power supply or a defectivemotherboard. Just to make sure that nothing else is causing the problem, removeany PCI cards like modem, video card, sound card, etc... Remove the memorymodules and disconnect cables to CD/DVD drives. Look at the USB ports to see ifany are damaged.
Feb 14, 2011 | Dell Inspiron 518 Desktop Computer
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
I have a 2000 suzuki marauder vz800. the front carb isnt getting fuel and the carbs have been freashly rebuilt. i am getting fuel to the rear. i cant tell if the fuel pump is working. it is brand new...
This is a common problem with vz800 models, I had the very same problem front ran lean and rear ran rich. I would advice you to do the following strong. change the frot jet to 130 rear to 135 and both needles should be 3rd from the top. it's not your fuel pump it rarely goes bad.If there is back firing then turn the carb. screw out by 31/2 turns. hope this helps. PS: it is not your petcock, nor your fuel pump. One advice have you gas tank cleaned and line it with POR only it is a good product.
Dec 07, 2010 | 2000 Suzuki VZ 800 Marauder
Need proper steps for convertible top operation
The top can be used as a sunroof or taken off completely. For the sunroof, you only have to unclip the two clips by each sun visor, and fold the front bow back so it sits on top of the roll bar. There is a velcro strip that goes through a hole in the front bow, to keep it in place.
To totally take the top off, you again uncleip the 2 clips by the sun visor. When the front bow is moved partway back, the material on the front bow is loose. There are sliding clips on the front of the convertible top that are slid along the front bow, so that the material is removed from the bow itself. Along each of the doors is an elastic clip that needs to be removed. Now the front of the top is pretty loose. Around the rear windows is a metal bar, with fabric snapped around it. Undo the snaps. Then forcefully push the metal bar outwards. The material around the rear window area can then be removed from around the metal bar. At this point, you can probably unzip the rear window. There are 2 pieces of plastic that slide into plastic grooves at the very rear of each corner of the car, that hold the rear of the top down. You just pull the rear of the fabric away from the rear corner of the car. And that's it.
Dec 06, 2010 | 1994 Suzuki Sidekick
How do i install the visors in my dodge stratus 2000 SE 2.0, and where exactly do i connect the power cords to to get the power to get them to work, and how do i connect them to my car video stereo ? if u...
connect the red wire to the red/white wire here is the wiring diagram
2000 Dodge Stratus Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Yellow
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange/Brown
Car Stereo Dimmer Wire: Black/Light Blue
Car Stereo Antenna Trigger: Orange/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
pls rate
Aug 17, 2010 | Pyle PLVSR72GR Sun Visor Monitor
Computers & Internet Logo
205 people viewed this question
Top Sun Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
