Question about Lexmark X2670 All-In-One Printer
I have the Lexmark X2670 and a couple days ago I scanned a document. Now I am not able to print anymore, I have items waiting to print when I check the printer, but the printer continues to print out scans, how do I fix this?
  • Official Brand Answer
  • 3,344 Answers
Reset your printer by unplugging the power adapter from it(small black box behind the printer where the power cord is attached). Wait for at least 10 seconds before plugging the power adapter back in the printer.
Clear the print queue first before sending another print job. Follow the steps below:
Posted on May 03, 2011
I can't get my Lexmark X2670 to scan and transfer the document to my computer other than as a .JPG file which is taking up too much space.
Try to access the Lexmark Productivity Studio. Just click on Start > All Programs > Lexmark 2600 Series > Lexmark Productivity Studio.
You can try scanning to PDF. If that option is grayed out, you'll need to install the OCR found in the installation CD of your printer.
Jun 14, 2012 | Lexmark X2670 All-In-One Printer
When I scan an 8x10 document, it comes out a 4x6 copy? What can I do?
Make sure to select the correct scan setting. Adjust the scan settings for the printer using the Lexmark Productivity Studio (for Windows) or the Lexmark All-In-One Center (for Macintosh).
Sep 19, 2011 | Lexmark X2670 All-In-One Printer
Can not scan with lexmark x2670
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark X2670 All-In-One Printer
My lexmark x2670 prints copys but it will not scan a document ocr it scans but will not process it .,then tells me it needs a program that has been deleated or lost i am using vista 32bit noel
You will need to update the printer software installed on your computer to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. Just re-insert the install disc into the computer hard drive and run the installation setup.
If you lost the disc, please contact Lexmark Technical Support Center for assistance.
Aug 10, 2011 | Lexmark X2670 All-In-One Printer
Unable to scan, however it does copy??
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Follow the simple steps below:
  1. Disconnect your printer from your computer.
  2. Reboot your computer.
  3. Unplug and re-plug the printer into the power source to reset it.
  4. When the printer turns on, reconnect it into your computer.
  5. Try to scan again.
You can also re-install or update your Lexmark X2670 printer driver by visiting the Lexmark website at http://bit.ly/hTPEL5. Also, if you are scanning a document for editing, make sure to install the Lexmark OCR scan software. The scan software can only be installed using the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 01, 2011 | Lexmark X2670 All-In-One Printer
Lost the directions for the printer directions need to know what button is for scanning pictures,
Follow these steps on how to scan from the Lexmark X2670 printer using the operator panel. 1. Open the top cover, and then load an original document facedown on the scanner glass.
2. Close the top cover to avoid dark edges on the scanned image. 3. Make sure that the printer is connected to a computer, and that both the printer and the computer are on. 4. From the printer control panel, press printmastert_51.jpg 5. If you are using a Macintosh operating system, click on the document or image preview and drag to select the part that you want to scan, and then click Scan from the Scan dialog on the computer screen. 6. If you want to save the scanned image, then from the software application, click File > Save As. 7. Enter the file name, format, and location where you want the scanned image saved. 8. Click Save.
Source: Lexmark X2600 Series User's Guide
May 11, 2011 | Lexmark X2670 All-In-One Printer
How do I scan from a Lexmark X2670 to PDF?
You need to install a PDF writer program first. There arequite a few freeware PDF writer programs on the Internet you can download onesuch as CutePDF.
Scan your document then click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. http://www.cutepdf.com/
Mar 11, 2011 | Lexmark X2670 All-In-One Printer
Lexmark X2670 printer not working with Windows 7
Did you upgrade the driver to a Win 7 driver?
If you did not, go to the Lexmark website www.lexmark.com Go to the driver download page and get the Win 7 driver for your printer.
Be very careful to follow the directions and completley remove the printer's software prior to installing the new driver.
Don
Jan 22, 2010 | Lexmark X2670 All-In-One Printer
I got your Lexmark X2670 and the CD, I installed
send you the link where you can all printer related issues:
http://support.lexmark.com/index?locale=en&userlocale=EN_US&productCode=LEXMARK_X2670&page=recommendedDownloads&segment=DOWNLOAD#1
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
Sourav
Jan 02, 2010 | Lexmark X2670 All-In-One Printer
Lexmark x3550 not printing anymore
You may have to remove power from the printer and disconnect the data cable, then reconnect the data cable and apply power to effectively "reset" it. Check the device list at the computer to determine whether the printer is active.
Nov 05, 2017 | Lexmark Office Equipment & Supplies
Lexmark X2670 All-In-One Printer Logo
136 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
